Positive battery terminal hot, smoldering smell
I'm an hour into a trip from dc back home to New York. Noticed a mild smoldering smell and pulled over. Nothing in the engine compartment but the positive battery terminal is hot to the toh and was actually cooking the piece of rubber (kitchen glove) I had over it to help insulate. I think that's the cause of te smell, but what's the cause of the heat?
Old 03-13-2016, 11:45 AM
No obvious signs of electrical issues. Fuse box is fine. Battery is cool. Negative terminal is cool. Gauges are fine. Lights are fine.
Old 03-13-2016, 11:49 AM
76 911S Targa
You need to check the voltage at the battery, while the car is running, which should be about 14 volts. Sounds like a problem with the charging system or a shorted battery.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 03-13-2016, 11:52 AM
That's my thought as well. Alternator seems fine as it was rebuilt a while back and gauges are ok. Shorted battery or cable corrosion. This car made a four hour trip down here yesterday with no issues. Trying to find a parts store at the moment. And debating just driving back.
Old 03-13-2016, 12:00 PM
wwest's Avatar
I see 2 possible problems.
Nut that tightens red accessory wires into good/FIRM contact with the battery post connection stud is not tight enough.
Red accessory wire stak-on's are not well crimped, best to flow solder them since trying to re-crimp will not work.
I would suggest addressing both.
Old 03-13-2016, 12:16 PM
Platinum Member
dad911's Avatar
Loose connection or corrosion, which is resistance in the circuit.
Power = I^2 times R (Current squared times resistance). Resistance in the connection with current = heat.
Spade lugs look rusty. Clean and make sure nut is tight.
Old 03-13-2016, 12:39 PM
Just found an advance auto.
Battery voltage is 14.
No drop from terminal to cable. Terminal is tight.
I drove here from my last post (30 mins) with no lights, no radio, no valentine. Terminal was cool to the touch when I arrived.
I think wwest may have this one. Will head home with stops to check heat etc. Soldering kit is at home. Not going to try to find one in south Baltimore in the rain.
Accessory stack nut was finger tight. Not even. Addressed that. Will solder at home.
Truly appreciate the quick responses.
Old 03-13-2016, 12:48 PM
