-   -   Help changing the fog light switch? (http://forums.pelicanparts.com/porsche-911-technical-forum/905948-help-changing-fog-light-switch.html)
terenann 03-13-2016 08:23 AM
Trying to gain access to replace fog light switch on a 1976 911. I also will put the correct lighter in at the same time. It does not have a dash centre speaker. Tried removing the radio and no access. I don't think I can gain access through the glove box. Not sure which way to go! I hope that the only way is not to remove the dash:(http://forums.pelicanparts.com/uploa...1457885871.jpg
http://forums.pelicanparts.com/uploa...1457885991.jpg
Algernon 03-13-2016 08:25 AM
Try through the clock hole! Helps if you have small hands.
JQ911 03-13-2016 08:35 AM
Trying to replace my foglight switch also in my 86. I tried all options within the dash including the radio but no luck. Believe it will best to access the rear end of the dash from the frunk. Hope somebody can chime in as its been 6 months since I bought the switch but never had the time to do it.
terenann 03-13-2016 08:59 AM
I'll give the clock a try. I thought of that but figured there would be too many things in the way. Thanks for the tip!
I had 65 things to do on the car this winter and I'm getting down to the last few. Its been very enjoyable checking off each project as it was completed. Spent a lot of time working on the car with my son. His enthusiasm is contagious. Time very well spent!�� It doesn't get any better!
