-   -   Throttle position switches question (http://forums.pelicanparts.com/porsche-911-technical-forum/906481-throttle-position-switches-question.html)
198491132 03-17-2016 11:50 AM
Idle position switch question - failure result?
Idle position switch question, sorry for the confusion. Idle position switch fails continuity test. Continuity remains from idle through full throttle. Bentley 240-20 electronic test says continuity should only be upon idle.
Would this cause break up/backfire under load?
Thanks, Dave
