Gurney Flaps / BA's book cover
If you look closely on the front cover of Bruce A's book nearly all of the cars in the shop have a small extension to the trailing edge of the wing/tail. The extensions look like a 1 or 2" strip of perspex held on by little rivetted plates.
I assume they are some kind of Gurney flap arrangement? Anyone got any better idea as to what they are and if they help? Chhers - Ryan |
Navin Johnson
Yes thats what they are (gurney lips)..... has some effect of breaking turbulence and smoothing airflow after the wing or something.........
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Obrut - You asked a very simple question -- the answer of which has most likely justified a number of PhD's!
I could just say that it tends to make the wing work better (increase downforce) under certain circumstances, but that wouldn't do the subject justice. For a sampling you might want to check out some of the articles on this site. They even have a paper dedicated to Gurney Flaps.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 12-13-2002 at 06:44 AM.. |
RE: the above post....the gurney flap does not increase lift...it is not an airfoil.
Gurney flaps have been used for years on aircraft and are used to spoil or reduce the amount of lift...in this case, downforce the wing produces at higher speeds. In other words, too much of a good thing (lift or downforce) can be undesirable. So the flap is installed in order "fix" this problem. It does not usually detract from the performance of the airfoil at lower speeds.
12' GT3 18’ 991S Last edited by avi8torny; 12-13-2002 at 09:43 AM.. |
Metal Guru
From the book "Competition Car Downforce" by McBeath: "The Gurney flap is a small, right angled strip bolted to the trailing edge of the rearmost element of a rear wing. It is a means of adding downforce with suprisingly little drag penalty, in spite of it's apparant crudeness.
"Recent research has now shown that the Gurney forms a pair of counter-rotating vortices behind itself, which has the effect of adding a verticle component to the velocity at the trailing edge. This deflects the flow upwards and increases the downforce. The effect is the same as adding more camber to a wing. One of the main advantages of the Gurney is that it is easily fitted and removed, or replaced with one of a different size and it is thus an important part of the fine tuning kit that racers take to the track. " Small Gurney flaps give rise to increases in downforce for a small extra drag component, whilst larger Gurneys add smaller extra amounts of downforce, but bigger chuncks of drag. There are sensible limits to work to here and Gurneys are usually less than 5 % of chord in height."
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
There is a difference between a Gurney Flap and a deflector...I believe the one's on the cover of the BA book are deflectors which increase the downforce.
excerpt from yarchive.net Newsgroups: sci.aeronautics.airliners Date: 17 Dec 96 03:09:15 From: David Lednicer Subject: Re: gurney flaps nicole wrote: > hi, i'm trying to find more about gurney flaps and don't know where to > get started - they don't seem to be in any of my aero textbooks. anyone > have any suggestions? could you please email me with them? > thanks, nicole Bob Liebeck of Douglas is credited with first bringing them to the attention of the aerodynamics community, but they are named after Dan Gurney, the famous race car driver. Several years ago, sitting in the bar avoiding attending paper sessions at an AIAA meeting, I asked Bob for the full story. He told me that Dan Gurney suggested to him the idea, based upon the old "spoilers" added to the aft end of race cars in the late 1960s. These "spoilers" were simply sheet metal tabs, added to the end of the rear deck, projecting upwards. Gurney reasoned that if, they worked there, why wouldn't they work on the trailing edges of wings? They tried the idea and it worked! For a flap that was 1-2% of airfoil chord, projecting perpendicular to the airfoil trailing edge, they got a useful increase in lift (downforce for a car), without much drag increase. Bob first published the concept in a 1976 AIAA paper (76-406). This was later reprinted in the September 1978 AIAA Journal of Aircraft. When the flaps first showed up at the Indy 500 on Gurney's cars, competitors asked him what they were for, so Gurney had an explanation ready. "When we push the car out, with our hands on the trailing edge of the aft wing, we tend to get cut up, so we added this tab to blunt the trailing edge." Competitors thought that this was a good idea, but they put their tabs on projecting downwards, rather than upwards, as needed to improve downforce! It was several years before they caught on. Actually, designers have used strips on the trailing edge of control surfaces before, which look much like Gurney flaps. However, they were intended to reduce control surface oscillation caused by wandering separation patterns. ------------------------------------------------------------------- David Lednicer | "Applied Computational Fluid Dynamics" Analytical Methods, Inc. | email: dave@amiwest.com 2133 152nd Ave NE | tel: (206) 643-9090 Redmond, WA 98052 USA | fax: (206) 746-1299
12' GT3 18’ 991S Last edited by avi8torny; 12-13-2002 at 03:23 PM.. |
