-   -   Access to battery - 3.2 (http://forums.pelicanparts.com/porsche-911-technical-forum/906732-access-battery-3-2-a.html)
OneMore 03-19-2016 09:33 AM
Hi Guys,
A newbie's question/comment... I'm trying to replace my battery. How is it possible that there is such a confined space to access the battery terminals?
any hint?
http://uploads.tapatalk-cdn.com/2016...d86c10f780.jpg
Algernon 03-19-2016 11:02 AM
It's really not that bad once you get the handle out of the way.
RSTarga 03-19-2016 11:48 AM
You have to first remove the battery hold down clamps, then slide the battery out to remove the terminals.
OneMore 03-19-2016 01:26 PM
Thanks guys.
Using the right tools and bit of patience helped [emoji16]
Daves911L 03-19-2016 01:35 PM
Quick tip: Remove the negative terminal first and pull it securely out of the way. It may save you some excitement later, since its very easy to touch the wrench to the chassis when getting at that positive terminal.
