How To Adjust Timing & Mixture on Twin Plug Carrera 3.0 Engine?
How does one go about adjusting the timing on a twin plug Carrera 3.0 engine with an older Electromotive crankfire ignition system? My mechanic says the timing is too advanced. Also, he was going to adjust fuel mixture, but said he couldn't find the fuel mixture adjustment screw for the CIS injection system installed. Any reason why someone would remove it? Any other way to adjust the fuel mixture on a CIS car?
Old 05-14-2016, 11:48 PM
Air Medal or two
afterburn 549's Avatar
What other kind of CIS do you have ?
He is scaring me...
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 05-15-2016, 12:00 AM
kent olsen's Avatar
28 deg total advance (adjusted above 3000rpm) on my twin plug 3.0L
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 05-15-2016, 09:36 AM
Thanks Kent. Do you have crankfire ignition, so no distributor installed? If so, ho do you adjust your timing?
Old 05-15-2016, 09:38 AM
kent olsen's Avatar
Sorry no, twin plug distributor
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 05-15-2016, 12:04 PM
Dr J's Avatar
Go here and look for the model you have.
Manuals and Technical Docs - Electromotive
I have been using the old HPX system for a few years. Turn a few knobs and voila, timing adjusted. I also check with a timing light as it is difficult to be precise on the printed numbers.
As for the mixture, can you take a picture of the engine bay or fuel distributer?
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 05-15-2016, 12:46 PM
T77911S's Avatar
dyno
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-15-2016, 09:50 PM
wayner's Avatar
Hi Kent
What compression are you running?
(We are about to fire my 10.5:1 3.0 up for the first time )
SOLD - 914 wide body hot rod
Old 05-16-2016, 04:28 AM
