advice needed: rod knock and poor leakdown in one cylinder on twin plug 3.2?
Advice needed.
I brought my car in for an valve adjustment since I thought it was a starting to get noisy
They with the valves adjusted they put it back together and it still knocked. They are tracking it down to rod bearing? No ideal if it’s big end or small end. Motor only has about 70k miles with twin plug head.
What would I need to do to address this? They said all the other cylinders were really good at 2-3% percent leak down but #6 was low at 19%. Broken rings?, cracked piston? No real sign of excessive blow by I have notice. They also didn’t think it was a broken head stud since the car dosent leak any oil.
Wondering what to do now? Rebore all cylinders with larger 98mm pistons? rod or rod bearings? Mic the crank at the offending big end?
Very much obliged if you can share your opinion here
Regards
PF
Old 04-05-2016, 07:19 AM
You disassemble until you find the problem, basically, and take it from there. Maybe a second opinion, since they're not sure of anything.
206 637 4071
Old 04-05-2016, 07:49 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
or leave it alone until it grenades - then you know it needs attention. Seriously, find the issue before a rod finds its way through the case!
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 04-05-2016, 08:27 AM
ok thanks guys...im seeking a 2nd opinion
Old 04-08-2016, 10:13 AM
