Jayboundless's Avatar
Momo shifter help
I'm looking to replace this tired shift know with a stock knob on my 1969 911. How does this thing come off!? And the new reproduction know is not threaded. Is there a compression ring I'm supposed to have?
Jay B.
85' 911 - Black
69' 911 - Signal Orange
Old 04-07-2016, 12:55 PM
nameisbauer's Avatar
Send a message via AIM to nameisbauer
The part That says MOMO in the the picture is threaded. Loosen that ring. It either comes off or it hides a set screw, I cant remember.
Jim
911 Mint Green "RSC" #mintgrun
911 Gentlemen's Rallye 85 Carrera GP White
2012 C63 AMG Mars Red
Old 04-07-2016, 12:59 PM
Administrator
Luccia at Pelican Parts's Avatar
Not sure if yours will be missing, but I believe there is a crush ring, which you can see HERE with Genuine and other knob options.
Old 04-07-2016, 02:18 PM
Unscrew the ring on the bottom, three set screws will be under there.
Matt - 84 Carrera
Old 04-07-2016, 02:28 PM
Jim is correct. I've got the same Super Anatomic. The threaded metal ring at the bottom of the knob hides one or more set screws. There are no crush rings on MOMO knobs, at least on this model. They're more astute than that.
Sherwood
Old 04-07-2016, 02:29 PM
The crush rings are for knobs that require a compression-fit install - factory-type knobs. None required if set screws are in the mix.
Old 04-07-2016, 03:21 PM
New one installed...Thanks everyone!!
Jay B.
85' 911 - Black
Old 04-08-2016, 09:54 AM
