Rhino Line'd my fuel tank
My 75 wide body project car needed a new fuel tank thanks to rust. When the new Dansk tank came from our host painted black....and I wanted protection similar to the thick, rubbery coating the factory put on tanks. I thought "Rhino Line it!" I have to say I am pretty happy with the results. It cost $100 to have done, and was finished in a few hours. Just a thought for anyone else.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles Last edited by Duc Hunter; 03-18-2016 at 01:17 PM.. |
Looks great!
"There is no old Porsche, just a new Porsche owner"
Looks rugged! Any idea how much weight it added?
I did not weigh it.....but between carrying it in and carrying it back out to my car...negligible......especially considering the protection. Some bed liners are laid into the bed like 1/4"+ thick. This is no where near that thick.... I think a gallon of Rhino Liner is about 5lbs...and there used less than a quart I would imagine.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Good thinking outside of the box.
Andy Bullen
looks awesome
76 912E - Grocery Getter 04 Toyota TacomaTRD - Beater Truck 08 Honda OdysseyEXL - Family Hauler |
I recently bed lined mine as well. Turned out nice just like yours.
Hell, I might Rhino line my entire car!
1976 911S MidYear Fever is alive and well. |
1973 Porsche 911 RS 1981 Porsche 931 Euro-Intercooled-GT 1984 Porsche 911 Euro Carrera widebody 1987 Porsche 924s Rallye Spec Instagram: @soyracer |
Burn the fire.
Not a bad idea. Be sure to post before and after pics...
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
There was a Mythbusters episode where they did an entire car- it actually had less accident damage in their tests.
Rutager West 1977 911S Targa Chocolate Brown |
Diss Member
![]() I had a car like that about 30 years ago. Great commuter car for $75! You know how people on the freeway will just start changing lanes through you? With this car they would start, take a good look, then recoil in terror! - 76 Corolla with red paint faded to a tasteful flat, almost orangish color. (√) - Visible damage on all four sides. (√) - The grill mashed in so I had to use a 6' prybar to get the passenger side headlight up high enough to keep from scaring nightcrawlers. (√) - A special mod was the wheelbase on the passenger side was a little over an inch shorter then the driver's side so it would go around left turns like gangbusters! (√) - And the final crowning touch was a torn Raiders bumpersticker on the back with the "R" torn off so it read "Aiders". (√) ![]() (Uhhh, what were we talking about again?)
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
That looks great!
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (given to kid) 2021 Kia Telluride 2020 BMW R1250RS |
Can they do grey? Like something that more closely matches at least the grey that my '88 has.
It is a rougher feeling finish than the factory. You can coat it with something that then enables you to paint it any color. That is apparently not tough to do.
As for a whole car....the underside maybe. Our cars (most of them) has a rubbery coating on most of the underbody to reduce stone damage and noise. Rhino Liner, or something similar, would make a great substitute I think.
I used a DIY Rhino Line kit to do my tank in grey. Applied it with a regular under-body coating spray gun, though it can apparently also be either applied with a foam roller, or dabbed on with a paint brush. Very happy with the results and it looks very close to the original coating.
'70 911T (AKA Bottomless Pit) - Undergoing restoration '13 Audi A4 1.8T - Surprisingly fun means of getting to work |
