Speedometer Removal
Gents,
My odometer and speedometer on my 1969-911E is not working at all. I have searched the forum for removal of the speedometer and I understand that they(early models-year not specified) are held in by two clamps and the later models (year not specified can carefully be pried out)... ...."On the very early cars, the gauges were held in using two small clamps behind the gauge. In order to remove the speedometer, you need to remove the two clamps and pull out the gauge. On cars equipped with cable-driven speedometers, you need to unscrew the cable from the back of the unit before you remove it from the dash.
I am trying to first pry out the clock so I can access the speedo, but here is my question...How early is early in terms of what year the author is talking about? Does the 69 year group fall in to that category??? or can it be pried out?
I bought some small plastic trim tools to help facilitate the removal...Once again thanks for the clarification in advance.
Gordon
1969 -911E
1967-912
Old 03-24-2016, 03:37 PM
All the gauges have retainer brackets on a '69. gotta go at them through the front trunk. Probably need to remove the fresh air box to get at the clock unless your hands are tiny.
206 637 4071
Old 03-24-2016, 03:58 PM
I was hoping that it applied to the very early cars 66-68! That's not what I wanted to hear! Thanks
Old 03-24-2016, 04:01 PM
What was the first year 911's were you were able to pull the gauges out without going through the trunk?
Old 03-25-2016, 06:21 AM
SCadaddle's Avatar
My 69 912 has the brackets holding the gauges, the fasteners for the brackets are merely knurled thumb screws---no tool other than your fingers required.
Old 03-25-2016, 10:21 AM
69Porsche asks:
On my 73.5 the speedometer and clock are held in my a rubber gasket that surrounds them. Not certain of the 'first year'.
Tom
Old 03-25-2016, 12:55 PM
I am looking at my dashes through my trunk and it seems like I have alot of hardware that I have to remove just to get to them...am I off base is this the case for your 911 set up as well?
Old 03-25-2016, 01:22 PM
Thanks! That's what I am faced with, trying to figure how to remove the airbox without damaging anything else to gain access to the gauges!
Old 03-25-2016, 02:14 PM
SCadaddle's Avatar
Start with the 2 Phillips head screws on either side of the plate holding the mesh screen to the body in the middle of the car between the hood and the windshield. The rest of it isn't that difficult to figure out.
Old 03-25-2016, 02:35 PM
Thanks I was able to remove the airbox! now my question is how do you know if the cable is not working or the gauge is not working?
Old 03-25-2016, 05:36 PM
SCadaddle's Avatar
I suppose you could jack up one of the rear wheels and with the car in neutral have someone spin the wheel while you look at the cable? Or even simpler just drive a few feet with the cable hanging into the open hole where the speedometer fits and see if it is spinning?
Old 03-25-2016, 06:41 PM
Thanks for the advice! You set me up to a path of success, much thanks for your insight!
Old 03-26-2016, 07:03 AM
