Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
WUR Questions...
On my 78'SC, i have a blue vacume tube from the WUR to somewhere. What would happen if i were to remove the tube?
Would the engine lean out? What if i remove the vacume tube an nothing happens?
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 12-18-2002, 06:06 AM
wckrause's Avatar
Which vacuum line is it? Your WUR should have two, one coming down from the top, and one horizontal at the bottom. The bottom one is connected to the thermovalve. The two vacuum lines are connected on either side of the throttle body, and act against each other. If you disconnect the top one, it won't make much of a difference, if you disconnect the bottom one, then the car will run rich.
Bill Krause
We don't wonder where we're going or remember where we've been.
Old 12-18-2002, 10:29 AM
