Loose fan belt
I'm trying to do a valve adjustment, and as I turned the belt pulley the belt just slipped instead of turning with it, so I couldn't get the distributor rotor to turn. I figured if I increased the tension it might not slip. So I removed the lock nut (which was cranked on there really tight) and removed some shims, and it made the belt very loose, contrary to what the service manual led me to believe what happen. Now I can't get it to tension up back to what it was before no matter what combination of shims I put on there. The belt is loose, and I'm stuck. The belt is old, so a replacement might be necessary but I just don't understand why it's so loose all of the sudden.
Old 03-22-2016, 08:10 PM
RETIRED
Joe Bob's Avatar
How many total shims do you have? Did you have any on the outside AND inside? How worn is the belt?
Belts are cheap, replace it and make sure you have the correct amount of shims and follow the BENTLEY manual. If it's a Hayne's give it the salt water float test.
2012 ML350 3.0 Turbo Diesel
Old 03-22-2016, 08:24 PM
Mark Salvetti's Avatar
When you removed the shims from under the pulley, did you place them on the outside before retightening the nut? You always need a total of 6 or the pulley half will be loose. Maybe when you went to reinstall, you didn't get the stacks correct?
Next time the way to solve the problem you had with the belt slipping, use your fingers to pinch the belt tighter while you rotate the alternator pulley. That extra tension usually is enough to rotate the crankshaft.
Mark
1979 911SC Targa
Old 03-22-2016, 08:41 PM
I have six total shims. I believe they were all on the inside before. I tried putting them all back on the inside (and yes I referenced the Bentley manual) and it's still not the same as it was before.
Old 03-22-2016, 10:13 PM
Registered Minimalist
75 911s's Avatar
Dome washer on correct? Dome faces the front.
Old 03-23-2016, 03:04 AM
83 SC
tkmoore's Avatar
With all the shims on the outside, wondering if the dome washer isn't seated in the notches on the pulley shaft all the way as needed, therefore outside pulley half isn't compressing toward the inner pulley like its dedigned to do? Tim
Old 03-23-2016, 10:21 AM
RETIRED
Joe Bob's Avatar
Try putting two on the outside and do the pinch test.
Old 03-23-2016, 10:22 AM
This...I've done the exact same thing, so I know it is possible. Be very careful when you put the dome and nut on that the washers are properly centered under the dome, otherwise it will get hung up. You will know if you see that some washers are no longer flat.
Old 03-23-2016, 11:09 AM
Dome washer faces the front? It seems to me like the rounded part of the dome should be closer to the rear of the car. Otherwise the dome washer doesn't make contact with the outer pulley half...
Old 03-24-2016, 09:22 AM
I think in this case "front" means the front of the alternator facing you, not the front of the car. The dome should be facing the nut. The spare shims actually are supposed to go under the dome. Here is the Pelican article with photos:
Pelican Technical Article: 911 Fan Belt and Pulley Replacement
The number of shims you need under the pulley is going to depend on the belt dimensions. They are all over the map these days. The original Porsche belts were 9.5 mm wide. The new belts, even though they may be stamped 9.5mm, are actually 10mm or more. See this thread: Can't get fan belt tight enough even with zero shims.
Mark
1979 911SC Targa
Old 03-24-2016, 09:49 AM
puddy's Avatar
Small hijack here, I have only 5 shims on my fan pulley, the removal instructions say "make sure you use 6 shims" well I don't have 6 shims and its been fine so far, any reason why 5 won't do?
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 03-28-2016, 07:35 AM
tobluforu's Avatar
No biggie, one was probably lost.
Old 03-28-2016, 07:44 AM
puddy's Avatar
OK thanks, I figured that much and didn't want to spend a fortune to buy 1 cheap little item and pay crazy shipping costs for it. I'll carry of with 5 shims.
Cheers, Chris
1986 951
Old 03-28-2016, 09:31 AM
75 911s's Avatar
Right. My wording was unclear. Maybe another way to put it is the dome covers the outer pulley half (or shims if you have them on the outside) and that the rounded part If yours is rounded -would be toward the rear bumper. FWIW my dome is not a dome at all, but the square type and I know there are a few variations in the washer...
And also I would put the 6th washer in. Now is a good time to buy a filter, gasket kit, and maybe a few other items to up you over the free shipping limit! :-D
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 03-28-2016, 11:35 AM
The reason for using all 6 washers is that the nut may run out of thread on the alternator shaft giving you a false sense of it's being tight when it's not.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 03-28-2016, 12:48 PM
sugarwood's Avatar
Post #16 may be helpful
Would like to try a compression & leakdown test at home.
1986 Bosch Icon Wipers coupe.
Old 03-28-2016, 01:10 PM
thats not the right washer. if that washer is beveled its supposed to go between the fan and the alternator. first that washer goes onto the alt shaft , narrow side towards the alt then the fan goes on
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 03-28-2016, 01:50 PM
