Home of the Whopper
Half shaft ?'s
Hello!
I was looking at a half shaft from a 73 911 and I noticed the two studs were broken off one side. I looked at the other side and noticed the studs weren't studs, they were some sort of wound metal strips. Can I replace the broken ones with metal dowels of an equivalent size? Why are they coils and not studs to begin with?
Thanks!
BK
Old 12-13-2002, 11:50 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
coils?
If you're talking about the wheel end of the half shaft ignore this. I haven't messed with that side at all.
On the engine side of my '73T's half shafts there are 4 allen bolts and 2 studs that fit into the differential. Can you get any pictures?
Are the bolts broken off or the studs?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 12-13-2002, 11:55 AM
Home of the Whopper
The two studs on either side of the half shaft are not studs. If you look at it closely it's actually a would piece of metal. My bolts are fine, it's the two "studs" that broke off. I can get pics later.
Thanks!
BK
Old 12-13-2002, 12:10 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Perhaps a roll pin? When putting mine back together the other night, I seem to recall thinking they were roll pins, but didn't pay much attention as they were unbroken.
Ever put a CV joint back together from scratch when you didn't disassemble it? Like a jigsaw puzzle without the picture
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 12-13-2002, 12:22 PM
They're not "studs", they're "roll pins" used to help align the joint. They should come with a new joint and be available individually through our host. If you search the archives someone may have posted the size, then you could get them at a local parts house.
Jerry M
'78 SC
Old 12-13-2002, 01:25 PM
Tim Walsh's Avatar
hmm.. since my engine/tranny is out of the car right now I'll take a look at mine tonight and if I can get pictures.
Tim
1973 911T
2005 VW GTI
Old 12-13-2002, 01:29 PM
