Rtrorkt's Avatar
Pic of Gauge please
does someone have a picture of the back of a oil temp/pressure gauge? Am trying to replace the bulbs and since mine is a 69, the unit is secured with the thumb screw bracket. I am trying to do this without struggling to remove the gauge. Need to see where the bulbs are placed
Also, in trying to pull the tach, it is hitting the steering column and does not want to come out. Does someone have a method to getting it out? Thinking i need to pull the bottom out to get it to slide but that was not working
Thank you
'86 944T black/red, chip, fuchs 8's and 9's- Sold
'97 Boxster silver/red, big mistake - Sold
'99 C2, silver/black, RoW M030 - sold
"69 912 white w/ '86 3.2L (like the pic, just not the pic)
Old 08-07-2016, 08:35 AM
Try removing the plastic steering column trim to make enough space to get the tach out.
I think it might be easier to remove a gauge than to try to replace the bulbs in-situ. If you can reach in there to get to the bulbs, you can also get to the bracket.
JR
Old 08-07-2016, 08:43 AM
