Ds1 Ds1 is offline
Best Piggy Back ECU for 3.2 turbo conversion?
When I eventually go turbo on my 3.2, I am planning on using the BEGI FPR for fuel, but spark hasn't been the easiest to figure out.
I DO NOT want a standalone ECU because of the complexity. The MSD 6AL programmable seems to not have enough spark retard. I could get a custom tuned chip but as far as I know there is no one around (Syracuse, NY) that could do it on a dyno like it should.
Is there a good yet simple piggy back ECU that's out there that I can control fuel and spark with but keep the nice basics and drive ability? This is a low boost 7-10psi application.
Thanks!
Old 04-09-2016, 06:32 AM
I would rather be driving
jpnovak's Avatar
Contact Sal Carceller. Do a MAF conversion and his matching chip. This should easily handle those boost levels.
Old 04-11-2016, 07:28 PM
Ds1 Ds1 is offline
Yes but then I'm still locked to that tune. Boost level isn't an issue at 7psi.
Old 04-11-2016, 10:41 PM
Turbonut
Raceboy's Avatar
Why would you need a piggyback? There is a plug and play ECU available for 3.2 that allows you to use any injectors etc you like.. Plugs right into factory 35pin DME plug via adapter harness or also available as straight Motronic version. Comes with built-in wideband controller.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 04-12-2016, 12:17 AM
Ds1 Ds1 is offline
Because then I have to program every little detail like I did with Megasquirt on my Miata which was not fun. I just need to alter fuel and spark and leave the rest alone.
Old 04-12-2016, 05:18 AM
jpnovak's Avatar
You can get an EEPROM burner and modify your own Motronic chip fuel trim and spark tables. I don't think there is a way to do what you are requesting over Motronic. You can reprogram the existing system or install a stand-alone.
AFIK there are no ROM burners or other real-timing tuning for Motronic systems in these cars.
Old 04-12-2016, 05:58 AM
Ds1 Ds1 is offline
How much is an EPROM burner?
Old 04-12-2016, 06:05 AM
jpnovak's Avatar
Start here. Look around post 130.
tuning programmable engine management systems
Old 04-12-2016, 06:53 AM
Turbonut
Raceboy's Avatar
VEMS comes with good running tune, including idle valve etc, you only need to adjust fuel and advance to your liking...
Old 04-12-2016, 07:50 AM
Grappler
Rodsrsr's Avatar
Plus one on Sals MAF conversion. Im assuming you're going low boost like .5 bar. Sal can easily program timing retard into the chip and with the new injectors, you wont even need the BEGI. You'll also be able to get rid of the old AFM and set up the MAF as a draw through system. A nice MAF will make that thing run like a new car. For a low boost setup its probably the best overall solution.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 04-12-2016, 09:39 AM
Ds1 Ds1 is offline
Yes, 7psi kind of thing. Max I would ever go is 10psi. I actually have an old Authority MAF I bought cheap and was going to mod a little for this same purpose.
Good point on the injectors. They are probably cheaper than the BEGI anyway!
Old 04-12-2016, 09:53 AM
Jonny H's Avatar
Our CDI+ has a simple 2D map for advance, based on RPM, plus it's a dual spark system. Works well on 930s. we are looking at adding a MAP sensor but it is a way off at the moment.
www.classicretrofit.com
Old 04-12-2016, 03:58 PM
