-   -   How bad is my rust? (http://forums.pelicanparts.com/porsche-911-technical-forum/908304-how-bad-my-rust.html)
DerkPerk 03-31-2016 08:07 AM
How bad is my rust?
Hey all. Picked up my first 911 last summer and loved it. As I put her away for winter, I noticed some rust under the battery. So yesterday I brushed away the dust and found a decent hole in the tray. My question is, can I cut out this tray and tack in some thing new or should I just treat it and repaint? The current battery isn't leaking and looks as at some point a previous owner put some silver spray on the spot.
Thankshttp://uploads.tapatalk-cdn.com/2016...c8e55ecc69.jpg
Dpmulvan 03-31-2016 08:41 AM
Rust is like cancer cut it out.
dfhtrhjn 03-31-2016 09:16 AM
Do you weld? Because this is the perfect first repair project to do once you've practiced on some sheet metal.
T77911S 03-31-2016 09:19 AM
spray it with osphoric acid and let it dry. brush off any loose material. then coat it with wurths.
do this top and bottom.
that's not bad at all.
based on the pic I would not cut it out. I don't even think I would fill in the holes unless it was a really clean car and then maybe not.
I would even grind away the paint around the rust just to make sure it is not under any paint.
GaryR 03-31-2016 09:19 AM
Yep, get in there with a grinder to find ALL of it.
Lake Guy 03-31-2016 12:22 PM
I agree, cut it out and weld in new metal. It never gets better with coatings.
DerkPerk 04-01-2016 05:24 AM
I do, never done sheet metal but I am up for trying. I agree with removing the cancer. Sounds like my upcoming winter project. I'll get it all cleaned up and neutralize any remaining battery juice so I can drive it this summer.
Thanks for all the input.
Cairo94507 04-01-2016 07:02 AM
Fix it right or don't fix it at all.
DerkPerk 04-01-2016 07:46 AM
Is that battery tray available or should I have one made up? What gauge would be a good choice?
