-   -   Denso Compressor Question (http://forums.pelicanparts.com/porsche-911-technical-forum/908366-denso-compressor-question.html)
Irhmsd 03-31-2016 04:38 PM
Are there Denso compressors out there that mate to a 3.2 but also have flared fittings versus the later O ring style? I need one if it exists.
kuehl 04-01-2016 04:43 AM
A new or remanufactured 911/930 Denso compressor does not come with compressor manifolds (what you connect your refrigerant hoses to). You need a good used set of compressor manifolds. The manifolds are designed for o-ring fittings. You could attempt to put flare to o-ring adapters on them however your current compressor to deck lid condenser hose fitting at the compressor side won't mate up properly. Hence you need to replace that hose as a minimum. If you intend to keep all the original 1974 hoses in the car you will be recharging the system often.
