derek murray's Avatar
14 pin connector - replacement pins?
One of the male pins of my 14 pin connector (engine bay) is broken. Are they available anywhere?
There is also a crack in one of the plastic retainers... are they also available or is it glue gun time?
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 11-26-2002, 01:49 PM
I believe the kit also contains the silver plated pins. See:
Broken 14 pin connector
Jim
Old 11-26-2002, 03:03 PM
Jbabic's Avatar
or your local dealer can order them if not in stock.
Old 11-26-2002, 05:15 PM
Thanks for the part number Jim as my local dealership didn't have a clue. BTW, below is a picture of the electrical connector kit.
'70 911S 1002938
Old 12-11-2002, 07:12 PM
I bought the whole kit and replaced it in my 80SC. I just want to warn you that you might want to mark the connectors prior to disassemble. The 14pin connectors are not all the same on all the models. Even the same year cars can be different depending on what accesories the car has from the factory.
Bob 80SC
Old 12-14-2002, 07:22 AM
Cool
Hey Bob.. the job is a solder thing or is the pins a slip fit, just curious..........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-14-2002, 11:15 AM
I did write down each pin location... good thing I did.
BTW pin replacement is a solder job.
'70 911S 1002938
Old 12-14-2002, 11:44 AM
