Question Tool for Boge strut
I want to replace my front Boge shocks with Koni's. I have lowered the strut, but I need a special tool to rotate the strut cap,
something like a 33-34 mm hollow hex. "101 projects" does not mention this tool and the Bentley manual only mentions a "nut wrench" Does anyone know this tool ?
Harry
1988 Carrera 3.2 Coupe
1967 MGB
Old 12-16-2002, 01:54 PM
GFCC
Jeff's Avatar
Just use a big pipe wrench. It will come right off, thats what I did.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 12-16-2002, 02:27 PM
it might be easier to leave the strut in place when you break that loose. A big pipe wrench will work. Also, best piece of advice on this topic is to use a liberal amount of duct tape on your fender lip so that you won't scrape your fender when you shove the new (difficult to compress) strut cartridge back under the fender.
Good luck!
Remember our friends: Warren, Ron, Grady, and Steve.
76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster
Old 12-16-2002, 02:55 PM
Certified Pre-Owned
BGCarrera32's Avatar
Big pipe wrench...give it a twist...your new strut insert probably has a new cap to thread in or it is part of the new cylinder...(my Bilsteins cartridges threaded in)...
Apply a little blue Loctite to the threads, tighten them down with your fan belt pulley wrench. Should get ya in the ballpark...
Good luck!
BG
'84 Carrera Coupe
Old 12-16-2002, 05:35 PM
Thanks for the info !
Harry
1967 MGB
Old 12-17-2002, 10:57 AM
