need part number... Please
So for some reason I've lost the small (think they are 5mm flange bolts) that hold the crank pulley onto the hub (964 motor)
I've looked in PET, but the versions I look at don't show a part number for the bolts... anyone know? Thanks |
is it 12A (m6x30 900 119 026 02) in this pic?
http://forums.pelicanparts.com/uploa...1459659648.jpg interesting - the pic didn't upload... try using this as the url -> http://forums.pelicanparts.com/uploads25/Capture1459659696.jpg 2nd edit - looks like a temp problem with graphics uploading tonight. anyway, try checking out the PN |
Thanks Dan, but that is for the upper pulley by the fan, I think.
These are to bolt on the lower pulley to a Hub, which in turn bolts to the crank. I'm not by my engine now, but they seem to be about an M6, maybe 10-12mm long and the bolt head has an integrated washer head. also, the threaded end is tapered |
| All times are GMT -8. The time now is 04:58 AM. |
