Best Wife Ever!
TwoTarga's Avatar
G50 Grinding
Just bought a 1987 Targa (G50 tranny). Tranny is mostly awesome, it seems, except for one quirk: depress the clutch pedal beyond the engagement zone, to within maybe an inch of the floor, and you hear a grinding noise. It sounds a lot like the noise you get in any manual when trying to shift into gear without the clutch pedal depressed.
FYI, the PO had replaced the clutch a few thousand miles ago. I don't see any leaking fluid around the pedals, not sure what else to try. I'm tempted to just build a clutch pedal stop, to prevent the clutch pedal from dipping into the grindy zone (the current rubber stop seems small/worn, though not sure exactly what a 'good' one should look like)... just not sure if this sound is indicative of a problem that might get worse?
Thank you!
Old 04-01-2015, 02:26 PM
Porsche-Poor
bcoats's Avatar
May just need an adjustment or perhaps the shift couple out of adjustment as well
1979 911 RS clone hotrod
1983 930 turbo-sold, will be missed
1992 964 C2 Coupe-regrettably sold
1980 911 SC Weissach-regrettably sold
1975 911S-sold but not forgotten
Old 04-01-2015, 02:44 PM
sugarwood's Avatar
I know nothing, but did some searching.
A few people have suggested "throw out bearing"
Clutch grinding noise - 996 Series (Carrera, Carrera 4, Carrera 4S, Targa) - RennTech.org Forums
clutch issue, grinding when fully depressed - Rennlist Discussion Forums
Clutch Noise - Rennlist Discussion Forums
1986 Bosch Icon Wipers coupe.
Old 04-01-2015, 02:51 PM
Cars and Cappuccino
tdw28210's Avatar
Sugarbritches is right. Throw-out bearing is the classic culprit in most of these cases.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 04-02-2015, 08:15 AM
Josh D's Avatar
Impossible!
The G50 is the Porsche Gods gift to 911 shifting!!
Sorry, non-constructive.........
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 04-02-2015, 09:51 AM
If the clutch (and presumably) the TO bearing were replaced a few thousand miles ago, I would not expect those to be the problem, but if they were improperly installed, that can do it.
I would look at the PO's records to see specifically what was replaced and see if they replaced the release fork bearings/bushings as well. Hopefully, they replaced the slave when the clutch was done.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-02-2015, 10:39 AM
I think it is due to the clutch pedal going down too far. A buddy had the same issue, and it was definitely not the TO bearing. You may want to do a bit more searching, as I am pretty sure this is a known issue for the G50.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 04-02-2015, 10:42 AM
gearhead
Old release fork broke after new clutch installed?
Hopefully not this.
Old 04-02-2015, 01:16 PM
Originally Posted by TwoTarga View Post
1987 Targa (G50 tranny)... depress the clutch pedal beyond the engagement zone, to within maybe an inch of the floor, and you hear a grinding noise.
The back of the release fork is being pushed up against and making contact with the outer ring of the pressure plate. If you look at the PP you'll notice the lettering on the front is now (scraped away) gone. Total pedal travel is supposed to be 140-150mm.
Old 04-10-2015, 03:08 PM
Best Wife Ever!
TwoTarga's Avatar
Thank you so much for the advice, all. I should have posted the resolution before now, my apologies... turns out it was a simple fix. There is a movable clutch stop behind the clutch pedal, visible by peeling away the carpet under the pedals. The purpose of the stop is to, well, stop the pedal from travelling too far. It had loosened and slid all the way up, allowing maximum pedal travel. A couple of trial-and-error locations, and (angels singing)... perfection.
Turns out that Josh D was right... the G50 really is God's gift to Porsche shifting! (assuming the owner knows about the silly clutch stop).
-Dirk.
1987 911 Targa, Guards Red - Bucket-list car!!
1980 911 Targa, Triple Black - Intro to air-cooled - Sold
2001 Boxster S, White - Rocket-powered go-cart - Sold
1979 928, green - Sold
Old 04-03-2016, 10:38 AM
spidklr's Avatar
Yeah, my '88 had the same issue when I got it (it would go CLINK CLINK CLINK when the pedal was depressed too far). In my case I needed not only an adjustment, but a new stop (bent) and pedal box rebuild (worn out bushings) and - unrelated to the noise - a clutch master cylinder (leaking everywhere)
1988 Stock Guards Red Targa "Hilde Gerg"
Old 04-03-2016, 11:45 AM
