Send a message via Skype™ to kyngfish
Spanner for fan?
Hi all. Coming up to my valve adjustment. I've heard 10k miles and I've heard "don't bother until the valves are clicking" I'm open to to opinions on that but! I don't have the half moon spanner to turn the fan. Anyone know of reasonably priced alternatives?
Cheers.
Old 04-04-2016, 10:34 AM
Just use a wrench on the nut holding the alternator pulley on. Will need to push on the belt with one hand if it's slipping, but that's doable. Problem will be when you want to change the belt eventually.... You'll need something to hold that pulley unless you have an impact wrench that can zing it off quickly.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 04-04-2016, 10:39 AM
Dooodahman's Avatar
Porsche Tools - Page 7
Andrew
1987 Carrera Cabriolet
1988 Carrera Coupe (RIP)
Gone are the days we stopped to decide where we should go......we just ride.
Old 04-04-2016, 10:49 AM
wrxnofx's Avatar
$37 is reasonably priced:
Fan Pulley Wrench PELTOLP209 - SIR Tools - PEL-TOL-P209 | Pelican Parts
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 04-04-2016, 10:53 AM
stormcrow's Avatar
go onto ebay they have lots of spanner wrenches listed chap.
SteveKJR
Proud Owner of a 78 911 SC Targa
"A Porsche does more then just go fast in a straight line"
Old 04-04-2016, 09:33 PM
Diss Member
Quicksilver's Avatar
As mentioned above, "... push on the belt..."
Just grab the belt on both sides and squeeze it together. That will keep the belt from slipping so you can loosen it. If you don't have the correct wrench for the nut you can use a 1" standard wrench or socket.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 04-05-2016, 04:59 AM
I'm thinking that most of us turn the engine using the alternator nut when checking valves. The wrench you're referring to is, IMO, used to counter-hold the pulley to keep it from rotating when you're removing the nut on the end of the alt. shaft, not really turn it per se.... You'd probably need to put a bit of pressure on the belt to turn the crank no matter which method you use.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 04-05-2016, 05:10 AM
Turn the alt pulley using a socket and ratchet while you push in on the right side of the belt. Leave the spark plugs in until you finish the valve adjust to keep carbon bits from falling onto a valve seat and causing an inaccurate adjustment.
206 637 4071
Old 04-05-2016, 06:28 AM
Use this with ignition OFF:
Sherwood
Old 04-05-2016, 11:23 AM
I dunno.... can you stop at TDC with that thing?
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 04-05-2016, 12:35 PM
wolds's Avatar
Cheers.
The valves get tighter not looser as you drive the car. Eventually if tight enough you will lose compression because the valve will not close all the way
Old 04-05-2016, 01:31 PM
Cevan's Avatar
I presume you checked your car's tool kit and it's missing.
1986 Carrera coupe - black on black
1972 CB500/4
Old 04-05-2016, 01:34 PM
as others have inferred, you need this tool to install the alternator fan belt. If the belt breaks and you don't have this tool (and a spare fan belt), you'll be stranded (since the fan provides necessary cooling for the engine and your 911 shouldn't be run without the fan)
Old 04-05-2016, 01:46 PM
Correct. Not for timing, but to adjust valves.
jlex
Piston doesn't have to be at TDC. That's just one method. However, a valve is completely closed (to adjust clearance) when the rocker arm contacts the base circle/heel of each cam lobe. And since the camshafts rotate at 1/2 the speed of the crankshaft, the crank rotates further than shown while a particular valve is closed.
Just bump the engine with the starter until the rocker arm contacts the base circle area, then adjust. But then I've digressed a bit from the main thread topic.
Sherwood
Old 04-05-2016, 02:40 PM
