Send a message via AIM to NoLift911
Best tool for removing turbo tie rod ends from strut...?
Just had my struts redone and need to remove to get the spindles raised ;-(
Have fresh paint and new turbo tie rods and don't want to damage with a BFH etc.
Anyone have a link to a tool that they know works for sure on turbo tie rod ends?
Thanks-
Jeff
Old 04-04-2016, 12:29 PM
Home of the Whopper
Sometimes you can put the nut back on and beat on it.
That way you don't damage the threads.
Make sure to hit square.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 04-04-2016, 12:49 PM
Mike80911's Avatar
Why not just go to the auto parts store and get a tie rod end removal tool through the loan a tool program?
Tie Rod End Puller at AutoZone.com - Best Tie Rod End Puller Products for Cars, Trucks & SUVS
89 930 Cab Black
11 Cayenne
Old 04-04-2016, 02:08 PM
IME (on other cars, not the 911) hitting the tie rod end (or spindle) laterally was most effective in breaking the taper loose. Usually I'd leave the nut on and once the taper fit was broken hit upwards using the nut, then take the nut off and finish it.
'80 SC Targa
Avondale, Chicago, IL
Old 04-04-2016, 02:25 PM
Garage dweller
Ducman's Avatar
You will be refinishing anyway after spindle raise (requires grind and weld) so grab the BFH it won't matter.
BTW I have managed to pop these off using a hammer without noticeably damaging finish. Just hit it square and don't drag it across surface.
Don Sjolin
IIIEURO AUTOWERKS
616.874.7932
Old 04-04-2016, 02:35 PM
kevingross's Avatar
I am not in favor of whacking suspension pieces with a hammer. I'd use a ball joint tool such as Matador Tools Catalog Page
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 04-04-2016, 02:58 PM
Driver's License Owner
The Watson's Avatar
If you use the ball joint tool, make sure to leave the nut on! I once used the tool and applied pressure and set it down. After a minute or two the tie rod end flew across the room, just above my head. Lesson learned!
Thanks -- Chuck
1977 911S Backdate Street/Track, 1970 911T, '70 Triumph GT6+ Vintage Racer Project, '60 MGA Restomod/tribute, Cayman R, 1967 Moto Guzzi V700
Old 04-04-2016, 03:05 PM
78sc's Avatar
I just removed my turbo tie rod ends yesterday. $13 bucks at O'reilly's.
Phil
1978 911 SC
Old 04-04-2016, 06:36 PM
wrxnofx's Avatar
Rent this tool. It's free and works just fine. I used it this past winter.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 04-04-2016, 09:01 PM
Does the tool have a manufacturer - no O'reillys in my area..
Jeff
Old 04-05-2016, 07:30 AM
76 911S Targa
Harbor Freight has the same tool. Any auto part store or Sears does too.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 04-05-2016, 08:26 AM
GeorgeM's Avatar
I have this version and it works well. I think I got it on ebay.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 04-05-2016, 08:52 AM
Pelican sells this one, which I have, but the ball end tends to roll off the tie rod shaft sideways. It needs a cup on the end so it stays on the shaft.
206 637 4071
Old 04-05-2016, 02:27 PM
Yeah I was looking for the one that has a cup on the end so it does not slide -
Jeff
Old 04-06-2016, 06:26 AM
