Stiff fresh air cable
The fresh air control (the top control on the 3-control ventilation control panel) is very stiff and resists moving all the way to the left (off/closed) position. I can assist it manually by moving the levers in the luggage trunk area, but I assume something needs lubrication.
Before I start removing cables and lubing them and also any pivot points in the mechanism, anyone have any suggestions for what to go after first? The exposed cable ends look a little weathered, but overall the whole system is very clean and in good shape. I think it's just seen very little use before I got it a couple months ago. Even the noisy fan up there has quieted down with use.
Paul
Paul
'87 Carrera cab; '19 Ford Flex for the Dane and Lab; '17 Tacoma for truck stuff.
'96 993 cab (gone, oops); '82 SC (gone)
Old 12-14-2002, 02:11 PM
walt's Avatar
After having removed mine for some lubrication I just decided to replace it with a new one that I fabricated from a lawnmower cable - total cost about $10.00.
Walt
82SC 3.0
81SC 3.6
Old 12-14-2002, 05:48 PM
Certified Pre-Owned
BGCarrera32's Avatar
Howdy-
This shouldn't be too big of a deal. The first thing I'd do is a quick check to make sure none of the cables are kinked or hung up behind a hood hinge or hood strut, etc. There is also a cable that runs from the drivers side diverter box (I'll call it that for lack of a better name) over to the diverter box on the pass. side. A couple of 10mm box wrenches should pop the cables free at their connection points on the boxes, and maybe a squirt of silicone lube down the end of the cable housing will help free them up. I have never messed with the actual control levers box so I can't comment on that one...
Make sure once you pop a cable off you don't move the levers. That will help it all get back together the way it came apart.
-BG
'84 Carrera Coupe
Old 12-14-2002, 06:32 PM
