-   -   How do I tell which calipers I have? (http://forums.pelicanparts.com/porsche-911-technical-forum/908965-how-do-i-tell-calipers-i-have.html)
seymore 04-04-2016 05:18 PM
Hi there,
The title says it all. I have an 82 SC that needs pad and rotors. Ive never done brakes on my 911 and apparently there are A and M calipers? How I can I tell what I have? I did a search but didn't fine what I was looking for. Thanks for your help.
Flieger 04-04-2016 05:59 PM
Should be M's but post a picture to be sure.
seymore 04-04-2016 06:08 PM
Thanks Flieger. Im not near the car right now. I'll post one tomorrow.
seymore 04-05-2016 10:05 AM
Here are a few pics of the front and rear. Thanks for the help Pelicans!http://forums.pelicanparts.com/uploa...1459879495.jpg
http://forums.pelicanparts.com/uploa...1459879512.jpg
http://forums.pelicanparts.com/uploa...1459879524.jpg
http://forums.pelicanparts.com/uploa...1459879534.jpg
djpateman 04-05-2016 11:24 AM
Photos of the fluid inlet would be more telling. However I suspect that you have A on the front and M on the rear.
wolds 04-05-2016 12:34 PM
Originally Posted by seymore (Post 9066465)
Hi there,
Get with Eric at PMB. He's the pro
Bill Verburg 04-05-2016 12:36 PM
A front
M rear
pete3799 04-05-2016 01:04 PM
Or Bill:D
Tidybuoy 04-05-2016 01:49 PM
Stock SC's had "A" calipers in the front and "M" calipers in the rear.
"A" calipers can be identified by the spacing between the mounting bolts - should be 3.5"
"M" calipers can be identified by the spacing between the mounting bolts - should be 3"
Carrera's had A & M calipers too but had a larger spacer between the caliper halves to accommodate a wider rotor. Those are referred to as "Wide A" and "Wide M".
seymore 04-05-2016 03:38 PM
Thanks for the help gentlemen.
