Need help with DP 935 Windshield and details.
I am trying to piece together a rather interesting car I picked up a few months ago. It is a 1978 911SC with full DP fiberglass bodywork and 930 Turbo running gear. Information is scarce for this odd little duck. This particular car features the elongated DP windshield which deletes the wiper panel and goes all the way down to the edge of the front bonnet. I am trying to figure out what DP ran for a windshield seal/rubber. If anyone can chime in, it'd be much appreciated.
Also I am looking for some WIDE old school BBS E50 3-pc wheels for the back of this car, I believe it takes 15x13's. If anyone has some in their spares, please let me know. Cheers. |
Like these? Porsche bbs rims 3 piece 1976-1989
You do know you have to strip the wheel to remove the tires, don't you? I don't think many tire shops will do that, or they'll charge you $$$ to do it. I've done them before and they are a giant PITA. Make sure the special lug nuts come with these wheels. I think I delivered these with the bolts to owner's nephews shop aafter the wheels were swapped. IIRC it was an anthracite 78 or 79 930 with really bad paint that was peeling off. |
I pmed you some info on the windshield.
I run 13x15 Fuchs with a 7" backspacing. You would need at least 6" backspacing, but 6.5" - 7" would be better. I've never seen a 13x15 1 pc. BBS, 11x15's are pretty common. You might try contacting Harvey Weidman (Weidman Wheels), he could probably make you a set. He repaired one of my 13x15's a few years back. You should call DP in Germany as they may offer them, as well as info on the elongated windshield seal. |
| All times are GMT -8. The time now is 04:06 PM. |
