Cars Ruined My Life
impactbumper's Avatar
Brake Pad Choices
I know this has been discussed to death, so if you have no positive contribution, please forgive me and move on. I would like to get some opinion from those who are using aftermarket performance pads. What is the flavor of choice?
Expectations:
-Great initial bite
-Mostly street driving, canyon carving, high speed braking
-No track days, no DE, no ax
-Brake dust and noise is not concern
Thanks in advance.
Old 03-28-2016, 07:22 PM
I just replaced my brakes with restored calipers from PMB. Eric recommended porterfield pads....so I went with what the brake expert suggested.
I only have about 15 miles on the car since completing the job so I can't speak to their performance, but I'm confident whatever Eric recommended will be great.
Old 03-28-2016, 07:41 PM
Racer
winders's Avatar
Porterfield R4-S for street...I like PFC 11 on the track.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 03-28-2016, 07:43 PM
cashman's Avatar
No track days, no De's.... Any of the less expensive pads our host sells will be more than adequate. I use Metal Master on the street and Raybestos race pads on the track. Very happy with both. Did some Autocross and some beginner track days on the Metal Master's and they held up fine there too.
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 03-28-2016, 07:45 PM
Charles Freeborn's Avatar
Use OEM type pads for the uses you've described. The Textar are fine. Street/Track or racing pads are designed to work well at higher temperatures. You'll never get them hot enough on the street to work properly. I use Ferodo DS 2500's. They're great when they're up to temp, but not good cold.
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 03-28-2016, 07:59 PM
Cars Ruined My Life
In the past I used Hawk HpS and HP+ pads on other cars. What I am looking for is a better initial bite than Textar, Pagid, Mintex crowd.
Old 03-28-2016, 08:04 PM
Bill Douglas's Avatar
-C
My thoughts exactly.
My car is a 99% street car, so a big emphasis on emergency braking. The DS 2500 were horrible. The OEM ones feel a way lot safer.
Old 03-28-2016, 08:13 PM
cashman's Avatar
No disrespect meant here.....are you sure you know what your looking for needing more initial bite on a street only car? I would think the pads you mentioned would be more than adequate for spirited driving on the street.
Maybe your brake system needs refreshed and the problem you are trying to correct resides there and not the pads?
Old 03-29-2016, 04:43 AM
Cars Ruined My Life
Freshly build calipers, new lines and fluid. I am not trying to fix a problem here.
Old 03-29-2016, 06:33 AM
Cars Ruined My Life
Thank you, ordered a set of R4-S.
Old 03-29-2016, 06:34 AM
I use OEM. Why? I swear that the Textar our host sells are virtually "dustless". More time driving, less time cleaning wheels.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 03-29-2016, 06:57 AM
I did the same research and chose R4S for my hot rod, and for my 89.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-29-2016, 07:00 AM
ganun's Avatar
yeah, time spent cleaning wheels s%$#s, especially if they're white.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 03-29-2016, 07:03 AM
BFT3.2's Avatar
I know the OP wasn't concerned with track performance, with that I'll add that a set of R4-S's lasted me exactly 2 track days and maybe 600 street miles. I switched to Raybestos ST-43 which work way better then the R4-S did on track and surprisingly on the street too, even when cold. They however can be a little noise/squeely at times so prob wouldn't recommend as a street only pad. The degree of brake dust is huge as well. I might check out those stock Textars for street as Im sick of washing the brake dust off the car every other drive.
Chris, I assume your referring to these Textars?:
front: Part #: 911-351-950-08-M3
rear: Part #: 911-352-950-06-M3
______________
'88 911 Coupe
'98 Spec Boxster
'85 380SL Benz -Euro
Old 03-29-2016, 07:10 AM
I'm happy with the Textars on my SC, but I have also always been happy with the R4-S pads on my SE-R (which, granted, is a bit of a different vehicle from a braking standpoint.) They've lasted ages, too.
'80 SC Targa
Avondale, Chicago, IL
Old 03-29-2016, 09:35 AM
gduke2010
gduke2010's Avatar
I got my pads from Buckinghampshire High Performance in England. Seem to be good pads, no squeeks.
Old 03-29-2016, 12:59 PM
