unusual perplexing engine S/N
Doing some research for a friend. We have the engine out of a 67 soft window targa. the car Vin appears correct - 50xxxx, the engine type stamp is correct - 911/06 for a non-S soft window. But the engine S/N is very perplexing. It reads *911912*. The stars and font and all look very correct with no signs of molestation.
To our knowledge this is the original engine from a car that otherwise looks "normal". The number stamp is on the "back" of the casting rib as is correct for an early aluminum case but the numbers???? Anyone have any thoughts?? :confused: Thanks |
Your engine number is ok the 1967 engine 901/06 start 911191 that mid production .Sweet engine number.
Cool. I guess I was just predisposed to being suspect because of the "co-incidence" of this unusual number. I think I was also expecting a 6xxxxx Number. Thanks
Your vin number should be between 715-730
| All times are GMT -8. The time now is 08:59 PM. |
