Jbabic's Avatar
fire on the heat exchangers!!!
I replaced th 2.7 with a 3.0. the 2.7 leaked badly and of course all over the exhaust. needless to say, once got the 3.0 running I checked underneath for a looksy and noticed the heat exchangers on fire....I got the hose and played fireman.
question: assuming this is oil burn off, how shall I get the excess oil off the inside of the exchangers.
would a torch to heat them up once removed to burn off the excess oil do the trick?.....anyone else have this problem?
Old 12-15-2002, 04:33 PM
VincentVega's Avatar
I would suggest taking them to a machine shot and have them dipped in the hot tank. You could spray a few cans of brake cleaner in there, but the tank will get them nice and clean.
Old 12-15-2002, 05:03 PM
makaio's Avatar
Like Chris said, take them to a machine shop or radiator shop, and have them hot tanked to remove all that crap.
Old 12-15-2002, 06:56 PM
Call Lovelace Radiator at 863-3600 on route 4 in Hamilton. Alan can tell you if cleaning them will work.
Jim
Old 12-15-2002, 08:24 PM
Author of "101 Projects"
Wayne 962's Avatar
Motor oil doesn't normally catch on fire - I suspect that you might have something else going on, like a fuel leak? Or perhaps they were previously cleaned with some solvent that is still on there?
-Wayne
Old 12-16-2002, 01:23 AM
