-   -   No spark when cranking, but tries to fire briefly when I release the key? (http://forums.pelicanparts.com/porsche-911-technical-forum/910172-no-spark-when-cranking-but-tries-fire-briefly-when-i-release-key.html)
gsxrken 04-13-2016 07:58 PM
1986 930-
Just performed under dash and fuse panel replacement and car won't start. I don't have spark when cranking. However, after cranking over for several rotations, when I release the key (from crank position to the run position) the car sputters and some exhaust smoke wafts out of the tailpipe. It's like i don't have spark when it's cranking but maybe I do in the run position.
Does that sound feasible? Could a bad ignition switch do this? Given the amount of wiring work I just did, I tend to suspect myself rather than suspect a part failure. The car had no such issues prior to the rewire.
SoyRacer 04-13-2016 09:23 PM
Not a fun task. Sounds like switched connectors on the ignition switch. Common when fiddling in that area. Pelican has a section with wiring diagrams. Good luck to you Sir.
Jdub 04-14-2016 09:08 AM
This behavior is common after a rewire and incorrect attachment of wires at or to the ignition switch.
Several good threads to start:
http://forums.pelicanparts.com/porsche-911-technical-forum/373417-car-turns-over-but-doesnt-start-until-after-i-release-key.html and
Related:
http://forums.pelicanparts.com/porsche-911-technical-forum/434228-72-dies-when-key-released.html
gsxrken 04-14-2016 10:23 AM
Thanks for the replies. Some things to run down tonight
gsxrken 04-14-2016 01:53 PM
I thought the CDI ignitions didn't have the usual 12v to the coil and that you need an oscilloscope to measure 450v very briefly? I may be way off on this but this is my understanding fromsome recent reading. I'll try it for the heck of it tonight. Thanks
gsxrken 04-14-2016 08:19 PM
So some findings from tonight but still no spark-
CDI box whines with key on. Fuel pumps run
One in a while the car kicks over after cranking when I release the key.
I can't detect voltage at the coil when cranking or when on, but I think this is because the CDI sends pulses that a multimeter can't measure.
1. Coil has 672ohms between the center coil wire post and either of the little posts (in spec)
2. I get about .4ohms between the two little posts. (in spec)
3. Post 15 on 6 Pin CDI plug has 12.8v battery voltage with key on, drops to 11.2v while cranking the engine (is that too much of a drop?)
4. Post TD on 6 pin CDI plug right above post 15 has 7.8V with key on, drops to 7.1V when cranking (this one puzzles me... what is it, and should it be as low as 7-ish volts?)
5. Green wire ohms out at 675 at the CDI plug end
ischmitz 04-14-2016 09:43 PM
At this point maybe use an old spark plug connected to one of the spark plug wires and grounded to the engine. Then watch for a nice strong spark while cranking. If no spark you need to check for the trigger signal. The trigger wire is a COAX cable with inner conductor and outer shield. Not sure what you ohmed out. Did you measure from green wire to GND?
The TD connection is the output to the tachometer. It needs a pull-up resistor (inside the tachometer) to give meaningful signals. It will then show pulses (one per spark event)
Jonny H 04-14-2016 11:57 PM
The Bosch CDI should produce a spark down to about 7v although it will be weaker at a reduced voltage. 11.2 on cranking is fine.
The TD signal drives the tacho and should be around 7 volts so that is ok.
Are you sure the fuel pumps are running when the engine is cranking? Could you have misfired the fuel pump feed?
gsxrken 04-15-2016 02:34 PM
Maddening symptoms. I have the high tension lead from the coil with a grounded spark plug in the other end and am watching for spark as my son cranks the engine. No spark... until he stops and release the key, then I see one spark jump across the 10mm gap. Every time. Not a very bright spark, but one nonetheless.
If it didn't spark at all I would say CDI box or coil are bad, but the fact that it can spark drives me bananas. I don't know what to test next!
gsxrken 04-15-2016 02:40 PM
Thanks for ringing in here. No spark while cranking.
I measured the green wire by connecting my leads across the end two female spades in the plug. I guess that is to ground, if one of them is the ground wire. (Don't remember the numbers, but not the #15 one with 12v or the tach one, and not the ones that run to either side of the coil posts
miketori 04-15-2016 02:52 PM
could be as simple as a weak battery.
yelcab1 04-15-2016 03:05 PM
I hate to tell you that you need to go back and verify everyone of the connections you have touched. At this point, nobody knows where the error is, but it is something you did. FInd a wiring diagram make sure your wires are connected correctly. Pin numbers and wiring colors must match
gsxrken 04-15-2016 03:16 PM
Like I said earlier, with the rewire I do suspect myself and not some part failure. Yet the issue with that is that I seem to have exonerated myself by determining that the CDI gets power to post 15 when in run or during cranking. When that's true, this thing should try to spark.
Here's a video of the condition... you can see one spark when my son stops cranking and returns the key to the run position. (Note that this is a spare spark plug lead plugged directly into the coil with a spare spark plug in it. It is not one of the six posts off the distributor cap, thus ruling out cap, rotor issues)
Battery is fully charged as per my green light on battery tender. I have a 10A charger on it during the starting attempts for the heck of it. What a pisser if it does turn out to be the battery, but with 12.8V at run position dropping to 11.2V during cranking at the CDI harness post 15, I think that's ruled out. And the car cranks well enough as you can see below.
ON EDIT- battery from other car installed and same condition exists.
<iframe width="560" height="315" src="https://www.youtube.com/embed/WJ_-oPTkwLw" frameborder="0" allowfullscreen></iframe>
ischmitz 04-15-2016 03:23 PM
There is one condition where the CDI box "locks up" and the only time a spark is released is when power finally gets removed from the CDI box. Maybe it is time to find another SC and swap your box in or get a loaner CDI box and check if that fixes it.
Can you confirm the box keeps whining (getting power) while you crank?
What exactly did you rewire?
Ingo
gsxrken 04-15-2016 04:14 PM
Ingo, I cannot tell whether the box is whining during cranking. I do know I have power to pin 15 during cranking.
My rewire was clock, glove box and dash lighting circuit related. I did upgrade to one of Johny H's new blade fuse panels while-I-was-in-there. I wasn't near the engine compartment once during the job. And even after the meltdown, I started and drove the car home, where it has sat for 8 months while I found time here and there to perform the very tedious main harness R&R.
https://lh3.googleusercontent.com/qr...0=w962-h721-no
https://lh3.googleusercontent.com/yq...-=w962-h721-no
https://lh3.googleusercontent.com/L_...I=w962-h721-no
https://lh3.googleusercontent.com/jf...s=w962-h721-no
ischmitz 04-15-2016 05:00 PM
Then maybe the CDI box has a problem if you do have power during cranking in T15. What bothers me is the spark that comes way later. It's not because of s trigger signal but because the box is powered down. That typically tells you there is a fault in the box.
Ingo
afterburn 549 04-15-2016 05:43 PM
As far as I can tell the op has not performed a voltage drop anywhere.
sugarwood 04-16-2016 04:25 AM
OP has an '86 930, but a Google search implies CDI box is for '69 to '77.
Which year cars have a CDI box ?
yelcab1 04-16-2016 08:18 AM
They all do, I was told. The CDI box in the 965 is called the EZ69.
yelcab1 04-16-2016 08:20 AM
GSX Ken, do you have a schematic of your car that shows the various control to the CDI box? There are two possibilities (at least)
1. Some control signal is keeping the CDI from discharging
2. The CDI is getting all proper signals, but it is defective
Having the bigger schematic does help troubleshooting. It is hard to do this over the web.
ischmitz 04-16-2016 08:26 AM
In the video the first and the second time the OP cranks you can see the engine (fan come to a complete stand-still) when the key is released. Nothing is moving and then almost a second later each time a single spark appears. This is consistent with a damaged CDI box.
Ingo
Jonny H 04-16-2016 11:07 AM
^. I'd agree. The box shouldn't ever spark without an input signal. The 6 pin expects a zero crossing signal from the VR in the dizzy. There's a slim chance it could be the VR coil but I doubt it.
yelcab1 04-16-2016 05:39 PM
I lean in that direction too. My last CDI on a 71T was buzzing like it is good but it was bad. A swap to a rebuilt box fired right up. If you are sure all wires are correct, then the CDI is the bad part.
gsxrken 04-19-2016 06:16 PM
Happy to post an update for those following along and future searchers:
I had reversed two wires on the rear of the tachometer and incredibly that was enough to lock up my CDI box.
I'm sure I would never have figured this out on my own, so I owe a HUGE thank you to Bob Ashlock and his spot-on advice quoted below:
"Consider the following: The TD pin on the CDI is the tach signal. This pin is intimately tied in with the internal trigger circuit in the CDI. I believe your car also has a Speed Relay, and the TD signal ALSO goes there. If something is honky with the TD circuit, it can freeze the trigger pulse circuitry in the CDI as I will explain below:
When testing a unit on the bench that is running normal, , if I apply (+12V) to the TD pin, the unit will STOP. If then shut off the +12V feed to pin 15 (as occurs when you let off the key), but keep +12V applied to the TD pin, and wait a bit, the moment I remove +12 from the TD pin, the unit will spark ONE time. That is because the discharge cap is charged and the transition of the TD pin triggers the SCR one last time to dump energy into the coil.
SO, the first experiment I would do is REMOVE any signal from the CDI TD pin and allow it to float. Cut the wire if you have to. Then see if the engine will start up. If it does, then the Tach itself, or Speed Relay, or something phantom must be forcing TD to +12V. The attached diagram only shows the TD signal going to 3 places: CDI, Tach, Speed Relay. spark ONE time. That is because the discharge cap is charged and the transition of the TD pin triggers the SCR one last time to dump energy into the coil.
SO, the first experiment I would do is REMOVE any signal from the CDI TD pin and allow it to float. Cut the wire if you have to. Then see if the engine will start up. If it does, then the Tach itself, or Speed Relay, or something phantom must be forcing TD to +12V. The attached diagram only shows the TD signal going to 3 places: CDI, Tach, Speed Relay."
Based on Bob's advice, I pushed the TD pin out my CDI harness plug and cranked the car, and boom, plenty of spark during cranking! This led me to suspect the tach, review my notes and photos and notice that I had two tach wires reversed... Switched them over, reconnected the TD pin in harness, and car now speaks during cranking.
One for the collective knowledge Pelican database.
