Bucketlist's Avatar
Fuel tank leaking
Posted on the Turbo forum also.
I have a small fuel leak at the bottom center of my fuel tank where it has bottomed out and scraped in the past. I have been smelling raw fuel for a while but this is the first time I have seen a drop of fuel hanging from the area. Can I seal this with epoxy or JB Weld?
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 04-13-2016, 02:41 PM
patz's Avatar
Radiator shop can look and tell you if repairable. They will fill it with water and weld it. You could try JB weld or just replace it.
Old 04-13-2016, 02:52 PM
Supermend Marine Grade Epoxy.
Used it on a fuel tank once... is impervious to fuel, oil, etc.
Very satisfied with it.
Check it out: 5330031 Super Mend 2 Part Epoxy Paste | Product Detail
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 04-13-2016, 03:57 PM
jb water weld is the only type thats good for fuel. but theres other products that are specificly for gas tanks like permatex instant gas tank repair
Old 04-13-2016, 04:41 PM
Bucketlist's Avatar
Thanks for the info. I will drain the tank today and let it dry out for a day or two. Since I am dealing with a pinhole leak I believe I will try the JB weld on the leak then I may fab a skidplate to protect this area.
Old 04-14-2016, 06:20 AM
I have same issue
Hi, I have exactly the same issue as you, PO grounded the tank and a pin hole has appeared
Ive considered
1) Marine grade repair patch
2) Relpace with Dansk tank but has no filter, would need in line filter, but seems to be cheapest new tank available
3) Have mine repaired, local shop quoted $150 to braize up, pressure test and rubber line, seems to cheap to be true though as another specialist wants $600 to do the same thing
Im going to try to patch with sealant ASAP, if I can find one that works. I have a few friends who have boat repair businesses, if I get something that works will post, then sort it out properly in the fall/winter when its off the road anyway, good luck
Old 04-14-2016, 01:11 PM
