Send a message via AIM to hahnmgh63
3.6 to 3.8 964 question
Anyone know if a set of 1995 Porsche Motorsport 993 RSR 3.8l jugs and pistons will fit a 964 '90 motor (pretty much the same block isn't it?)? Someone selling a low mile set with wristpins and all for pretty cheap $1000.
Old 04-14-2016, 04:36 PM
group911@aol.co's Avatar
They are probably bore in cylinders which means you would have to bore the spigots in your case. Sure they are RSR?
Thanks,
Bob
group911@aol.com
Old 04-14-2016, 06:30 PM
They are supposedly off a 993 RSR wrecked with only 1 or 2K on it. Only seen pictures up to this point.
Old 04-14-2016, 08:22 PM
Old 04-14-2016, 08:23 PM
prschmn's Avatar
The spigots look thin so they may be drop ins but at least standard 993s have narrower
small ends so 964 rods are not compatible.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
97 Van dieman F2000-gone but not forgotten
30 plus years of rebuilding services
Old 04-15-2016, 02:24 AM
Need to bore out your case... Not slip in. Also it's a sprint rsr piston I believe which the CR may be to high for pump fuel?
Old 04-15-2016, 03:09 AM
Bill Verburg's Avatar
There are several versions for these pistons, 1 for the wider 964/930 rods the other for the narrower 993 rods, also different cr's
RSR will have 109mm spiggots , the slip ins will have 107mm
RSR will also have tapered wrist pins
Bill Verburg
Old 04-15-2016, 04:42 AM
I need to see them in person I guess, and bring my calipers. He's 2.5hr drive but only asking $1000. I'd at least do a strip down of mine (90k) 964 and maybe Pauter rods or something.
Old 04-15-2016, 08:17 AM
