billh1963's Avatar
Pierburg fuel pump current draw of 12.5A...normal?
In a previous post I mentioned that I replaced the original Bosch pump with a Pierburg fuel pump om my '76 911S with CIS.
The original oxidized aluminum 16A fuse popped almost immediately. I then changed it out with a new copper strip 16A fuse and it has not blown.
Using a ammeter, the Pierburg is drawing 12.5A at idle. With a 16A fuse that doesn't leave much safety factor. Is this draw normal? Does anyone have a comparison value?
Thank you
Old 04-13-2016, 02:41 PM
T77911S's Avatar
is there a current draw on that circuit with the pump off.
if you can, disconnect the ground a or neg at the pump and check current.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-14-2016, 05:05 AM
billh1963's Avatar
No parasitic current draw at all.
Old 04-14-2016, 05:32 AM
billh1963's Avatar
Today I drove the car approximately 150 miles...no problem or distortion of the fuse. I'm calling this one done.
Thank you
Old 04-16-2016, 02:23 PM
