-   -   Why didn't I order a Steve Wong chip sooner? (http://forums.pelicanparts.com/porsche-911-technical-forum/910742-why-didnt-i-order-steve-wong-chip-sooner.html)
Raceboy 04-27-2016 12:16 AM
Originally Posted by 3rd_gear_Ted (Post 9090879)
Steve,
Can other providers of AFM's like VEMS or others plug and play with existing Motronic or do you need their specific ECU too for it all to work right
VEMS is not an AFM! VEMS is plug and play standalone ECU that works with stock Motronic wiring and sensors (you need to replace TPS with variable resistance one and intake temp sensor if you dicth AFM).
VEMS allows you to run engine without AFM or MAF, it uses internal MAP sensor.
This is VEMS 3.2 kit:
http://forums.pelicanparts.com/uploa...1457464079.jpg
Sorry for the OT, I just clarified.
mysocal911 04-27-2016 08:33 AM
Since you appear to be another "tuner", i.e. indicative of your other posts on the Pelican Forum,
maybe you can answer the question raised by this quote;
Originally Posted by Steve W (Post 9090830)
Generally on a n/a motor, full throttle AFR variations between 12.5 and 13.4 have very little influence on overall power output and reliability as that is the top of the bell curve. Maybe 2-3 hp at the most.
If it's not the tweaking of AFRs that help improve performance, how then can chip tuning increase
performance even at middle range for a totally stock engine?
Raceboy 04-27-2016 11:26 AM
I presonally would not tune 911 engine any leaner than 12.7-12.8 because on 2valve engines I have found that this is what makes best power and also helps to cool the combustion (since its aircooled), cylinder head temps have shown it very well.
But power wise the difference from AFR is neglible, most power increase comes from ignition timing like on any engine :)
Steve W 04-27-2016 12:26 PM
Originally Posted by mysocal911 (Post 9092342)
Thanks for the very helpful info. In reading some forums, many of us over the years like myself have
understood that tweaking the AFRs was critical to achieving peak performance for a fully stock 3.2 911
engine, e.g. stock exhaust/CRs. If it's not the tweaking of AFRs that help improve performance,
how then can chip tuning increase performance even at middle range?
Why do you insist on taking a my words out of context? So pay attention and maybe you may learn something today. If you reread my post, AFRs between 12.5 and 13.4 have little minimal effect on power output, but I never said 911s only run between that range. Quite the contrary as they run anywhere from 15.0 to 11.0. When they run that rich or lean, the power output can be off by as much as 15 hp or more and response very poor. And these dyno charts only cover full throttle, not part throttle where people spend 95+% of the time where AFRs are no where near 13 and what is most important to most drivers:
http://www.911chips.com/superflow3.2.gif
http://www.911chips.com/Superflow-chart.gif
More dynos:
911Chips - Porsche Dyno Runs
https://www.facebook.com/911chips/
But I have an unrelated question. After being banned for posting as a know it all condescending troll by the name of Lorenfb, why do you feel the need to come back posting under a fake name?
mysocal911 04-27-2016 05:34 PM
Thank you for your response and honesty! Many others who read that will have a better
understanding of tuning and will appreciate that when considering a chip for a stock engine, e.g. exhaust, CRs. Your knowledge when tuning 964 engines has been very helpful for the many 964
owners on the Rennlist Forum, and as such, highly regard your knowledge and follow your advice.
