Oil cooler fan temp sensor thread size
Hi -
I am in the process of upgrading my trombone unit to the later style. I won't be using a fan and the correct sensor is $86. I'd like to just plug the hole. Can anyone tell me the size and thread type of the sensor? Thanks Scott |
Well, you can always change your mind later.
But your question has me puzzled: :confused: Quote:
In stop and go driving, unless you live in the Arctic, even the 'later style' you mention, (and I presume it's the late Carrera type), can cause your oil temps to get out of hand. If you have a ER type cooling system, call Chuck Moreland and ER and discuss this with him. If not seek out a sensor activated pusher fan. Best, Tom |
Oil Cooler bung size.
3/4 in. depth. Use Anti-Seize. Good luck, Gerry |
Thanks Gerry!
I used a fan but not the sensor. I put a switch on the dash w/relay for fan control. Extremely helpful in stop/go traffic or when working on the car engine running.
Makes a big dif. |
| All times are GMT -8. The time now is 10:46 AM. |
