How far/Safe to drive somewhere?
Good morning all,
I recently serviced the drivers side CV joints on my 86 Carrera. The outer boot was torn but the joints were in good shape. I disassembled the inner, replaced the boot on the outer and filled everything with new grease. I got it all back together successfully and am happy with everything! That being said; as we all know the stub axle nut needs to be torqued to 333ftlbs. Needless to say I do not have a torque wrench that goes that high. I torqued to 150ftlbs and got it to go about another 1/3 turn until I couldn't move it any further. My local Porsche shop is about 25 minutes (20 miles or so) away and said they would torque it in the lot for free if I get it over there. I could definitely drive delicately to the shop but wanted to know how bad this would be to do. Am I going to destroy something? Should I just find a pipe big enough to fit over my torque wrench and do the math (100ftlbs with a 3'3" pipe should yield 333ftlbs I think)? I don't want to tear this whole thing back down to change out the wheel bearing or something. Any help would be appreciated. |
I wouldn't snipe a torque wrench.
There are torque multipliers out there that will allow you to increase the torque delivered by your torque wrench. Google "torque multiplier" there are probably youtube videos on the subject. I would guess that you should be fine to drive 20 miles but I wouldn't hammer on it! |
Get a breaker bar and put the pipe over it. I would be more concerned about hurting your torque wrench than the axle nut.
The axle nut WILL back off without the proper torque. Just a matter of time. You will be taking a chance driving 20 miles. |
It would fine for 25 mile 150lbs+1\3 turn your about 225lbs and dont forget to recheck CV bolts after 60 miles.
Torque is a multiplier in #ft
1/2 in breaker bar with a pipe over it Take your bathroom scale and step on it. 3 ft up the pipe from the nut press down on the bar until you have moved your weight back 115 # You now have 345 ft# of torque on the nut. Bruce |
Its not gonna back off in a short drive, the manual torque methods above are all I've ever done and without problems ever. That 333 or 345 number is big but we're not talking NASA accuracy required on 30+ year old cars and fasteners.
2' breaker bar, my 200 lb weight on the end. was close enough for me a few years ago.
I'd drive it over there.
Confused... |
i just replaced my CV joint boots, and i used my Harbor Freight Earthquake 1/2" impact wrench to attach the nut. I just gave it a few raps on the trigger, and Voila! Not sure of the torque, but i have had no problems.
Here is the nut. 32mm or a 1-1/4" http://forums.pelicanparts.com/uploa...1461079108.jpg |
Exactly. exactly enough at least... |
The shaft that goes through the wheel is part of the axle and the only way to remove the axle is to take the nut off and push the shaft through. Lots of fun to remove when the engine is out and you don't have anyone to push on the brake. |
My decent quality Craftsman or Kobalt 1/2" has held fine the several times I've worked on mine. Just put the pressure on downward if you think it'll break. Break it, take it back for a free replacement !
| All times are GMT -8. The time now is 09:28 PM. |
