Spacer for prototypo
Hello
What is the best spacer kit for the momo prototypi steering wheel? Is it eccentric? Not sure what this means when related to hubs and spacers. (I do know what eccentric means). Also is a 15mm spacer the best ? Seems to be the most common. Also what do you do for your speedo and rev counter- I,ve seen some rotated. Thanks |
Hey, nice marmot.
Eccentric means the wheel turns in an eccentric arc. A typical wheel the stays in the same plane as you turn. When an eccentric spacer the wheel will be closer at times and further away at others.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
trying to visualize, do you mean eccentric in the vertical plane (i.e. closer at times to your knees/seat bottom) or horizontal plane (i.e. closer at times to your chest/seat back)? Suspect it's the former (the hub center is not in the same place as the center of the wheel itself)
Hey, nice marmot.
Do a Google search for JWest eccentric hub adapter and you will see a video that shows it better than I can probably explain it.
Air Cooled
I bought one from our host that is made by MOMO: Part #: PEL-MOMO-SPACER
It puts my Prototipo right where I wanted it, so no longer hitting my fingers on the dash. It does set the wheel away from the turn signals, but you get used to it. Whether you want to spin your speedo or tach is up to you, but I didn't. Mind you, I can't see the speed limit up around 90...but I'm not really looking at my dash when I'm going that fast. ![]()
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - 2012 Ducati Multistrada S, 1995 Ducati 900SS LWCR '88 Honda Hawk GT, '77 Honda CB750K Cafe Last edited by Craig_D; 04-19-2016 at 11:31 PM.. |
I've bought several spacers from LTB motorsports, they sell a few different sizes and come with hardware
86FlatSix
I recently got this from LTB and installed it a week ago as the steering wheel I installed was too close to the top of the dash.
I chose the 1" though they also have 2" option. ![]()
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
I have the 2" from LTB and the JWest eccentric, works for me at 6'5".
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
This. I'm 6'6". I didn't do the eccentric, however. But I did rotate the speedo so I can see the needle up to 90 or so. First question everyone asks when they look inside.
1987 911 Carrera coupe - Guards Red 2005 Mini Cooper Convertible (R52) - Wife's car |
Air Cooled
...anyone else also notice the OP's Proto-"typos"? lol
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - 2012 Ducati Multistrada S, 1995 Ducati 900SS LWCR '88 Honda Hawk GT, '77 Honda CB750K Cafe |
Event he factory did not have a "best" solution, as there was a factory "raised hub" option that simply pushed the steering wheel closer to the driver. This might be desired depending on your physical build and seating position. There are many of these spacers in many different thicknesses available for aftermarket wheels. These spacers can be used with or without the eccentric spacer to best fit the wheel to you. |
Thanks At over 6ft tall I have my chair back so I can get my legs in and without a spacer I find I am having to slump forward to hold the steering wheel- which is not comfortable! Also my fingers rub the dash when steering- annoying but also not what I like. The spacer, probably 20mm would be ideal, would give clearance to the dash and keep me within the reach of indicator stalks etc.... Momo supply a 20mm spacer which I have ordered, hopefully this will be the solution for me. |
You should, it's a pretty wonderful combination. I have the oil, tach, and speedo all rotated to a visible angle now.
Thanks for the advice, StiG. Does the wheel feel funky when you turn it due to the fact that its height will change with the eccentric?
looks a little funky but I get how it works now.
Instagram: @aircooled.atx 1977 911S Widebody w/3.6 swap 1970 911T Widebody w/3.3 Turbo(In progress) |
That Guy
I am using the 1" spacer from LTB with mine, just about perfect for me. I am 5'11" and prefer to sit fairly close.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Doesn't feel funky at all for me.
So got the spacer!
However what am I doing wrong, as the horn button will not stay in. Anybody got pictures of there spacer fitted. |
Thread Tools | |
Rate This Thread | |
