Decel valve bypass
My Decel valve has likely died. When disconnecting one that's suspected of a diaphragm failure is in necessary to unhook and plug all hoses to and from, or just the smaller vac hose?
Thx. |
If just the diaphragm has broken, then I think you only need to plug the little hose that pulls on the diaphragm.
If you also have a leak on the valve portion itself, it's best to plug all three hoses. They're pretty easy to test - Vacuum pump on the diaphragm side and see if it holds vac. |
Thanks Jim! Should have asked you on Saturday.... Installing MSD now, then on to valve adj and decel bypass. Might make it to c 'n c if not too busy before track day on Sunday.
-C |
Cool - Would like to hear what kind of improvement you feel with the MSD.
| All times are GMT -8. The time now is 04:25 AM. |
