wwest's Avatar
Cabin Heat Modification
PROS:
1. Constant cabin heating level, no variation with RPM.
2. Additional engine cooling airflow.
3. Additional engine lid condenser cooling.
CONS:
1. No "parasitic" exhaust manifold cooling.
Old 04-20-2016, 07:34 AM
Which part is this and what years does it apply to?
Old 04-20-2016, 08:04 AM
so, it's a plastic plenum that works as a block off plate, but lets you keep backdated heat?
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end.
http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html
Old 04-20-2016, 10:00 AM
wwest's Avatar
Heat air flow comes ONLY from the 12v blower.
Old 04-20-2016, 10:21 AM
Hot air from the heat exchanger now has two exit paths, the heater control valve and these holes. What prevents the electric fan from forcing heated air through these holes and into the engine compartment?
Sherwood
Old 04-20-2016, 01:50 PM
wwest's Avatar
There is a metal blocking plate (excessive RTV sealant) to prevent flow to/from the engine, and the holes are on the suction side of the cabin heat blower.
Old 04-20-2016, 04:45 PM
wwest's Avatar
Results, 800 RPM:
FPM =125 CFM = 175.
With Cabin heat blower on:
FPM = 225 CFM = 315.
Air intake 1.4 sq. ft.
Extra cooling for the engine lid condenser.
Old 04-25-2016, 06:06 PM
