Stripped cv joint bolts
I have four hex bolts with stripped heads on my axle/cv joints where they connect at the wheels. Any suggestions on a solution? there must be a bolt removal tool that is made for this problem.
Thanks |
You can use a good pair vise grip.
Heat, as in oxy/acel torch + Kroil (or PB Blaster) + vice grips.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Home of the Whopper
You may be able to clean out the bolts and insert the driver deeper into the head. Use a mallet to sink it in good.
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
French Import
BFH and a cold chisel. Make a slot so the chisel will catch and try loosening by hitting with the BFH at an angle going counterclockwise of course.
I had to this for at least 2 bolts on each side.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Grappler
If all else fails you can cut the heads off with a grinder.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
vice grips work great so long as the brakes are on.
'90C4 |
My thread with the same dilemma...
stripped 10mm CV joint bolt question I ended up cutting it off with the heavier dremel cutting wheel. Good luck Mark
1989 911 Carrera 3.2 2009 Audi A4 2.0TQA 2017 BMW X3 2007 BMW 328xi 1971 BMW R60/5 |
John Walkers tool works amazing for this , I think sears has a version
The cold chisel method takes considerable practice and has unpleasant consequences if not done properly. Also difficult to do in tight spaces. I practiced for years on stripped out philips head case screws on Hondas.
Use the tool John illustrated. -C
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
83 911 Production Cab #10
I end up cut the head of the bolt flush with the CV joint, remove the CV and use a pair of vice grip to take it out.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Thanks to a quick search and the infinite wisdom of John Walker, 4 stripped cv bolts were out in no time. Thanks John . Tim
Care to share the model number and where you bought the kit?
Henry |
From lowes
![]() Not recommended to use with impact. For cv bolts the 1/2 inch/13 mm worked great, tapped on with rubber mallet and had all 4 stripped bolts out in 5 minutes. Good luck, Tim |
shoulda used the right tool in the first place. Tripple square 8mm if im not mistaken. cant use a torx bit
82 SC , 72 914 |
Fleabit peanut monkey
The only triple square I am aware of is for the door frame striker plate. I do believe it is 8mm. OP did not state year of car. If is is a newer 911, 964 and forward, I can't comment. Wish my 81 had triple square but it does not. I just replaced all of them a few years back. Hex ports were getting tired and I am sure me and PO ham handing things was the problem. I have the Irwin extractors. They are great but the bite can wear out over time on frequently used ones - i.e., 10mm size.
1981 911SC Targa Last edited by Bob Kontak; 08-25-2015 at 08:43 PM.. |
FYI Dude, I just bought the car and the damage was already done. Thank you for the insight though. Typical comment from a "self proclaimed genius" Tim
Give him a Mulligan. He is most probably pissed off about something else. It can happen.
1981 911SC Targa |
El Duderino
I fully endorse Irwin tools.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
