Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Administrator
Jack Olsen's Avatar
Building a better Black Beauty #6: The Master Plan
Since a lot of people are following the rebuilding of my crashed street/track 911, I thought I'd type together a (hopefully) comprehensive list of every modification the car will have when it goes to compete in the Touring division of next year's Open Track Challenge.
Here's my list.
1972 911T Non-Sunroof Coupe (9112100777)
Suspension and Brake mods
9.5x11x17 2-piece Lindsey Racing Fuchs-centered wheels with polished spokes
930 Brakes
Lowered to 24.25 inches front, 24 inches rear
Front JRZ single-adjustable struts, with coil-overs, modified by ERP and Tyson Schmidt, including raised and re-cambered spindles and extended control arms (by Tyson and also FABCAR of Indiana)
Front upper strut mounts modified for additional caster by TRE Motorsports
Elephant Racing front Monoballs
Turbo Tie Rods with drop links to correct bump steer
Elephant Racing triangulated strut brace
Aluminum front crossmember
Weltmeister 22mm front antiswaybar
Aluminum rear trailing arms with Smart Racing Camber Boxes and monoballs
Smart Racing 23mm rear antisway bar
ERP 935-style spring plates
Rear Bilstein struts and adjustable inserts with coil-overs
Engine, Driveline and Oil Cooling mods
3.6 liter engine from 1993 C2
I-G Engine Swap Kit, including Cyntex performance chip
B&B Headers with modified B&B muffler
Expanded-capacity 72 oil tank ahead of rear axle
Dual front fender oil coolers
Close-ratio 8:31 transaxle with external cooler and spray bar, 141 mph max gearing
Robotek Gate at shifter, Wevo internal gate
Guard Transmission Torsen-type limited slip, set at 80%
Zuc-Z air intake
Body mods
Fiberglass RSR front fenders, bumpers, hood, rear quarters, by Rennspeed Motorsports
Fibergass Rennspeed doors with RSA door panels, and sliding strap for window
Lexan on all glass except windshield
Welded reinforcements for front and rear antisway bars
RSR-style reinforcements to rear shock towers, caps, and rear crossmember
Battery boxes deleted
Misc mods
Reverse windshield wiper park
7 second delay on interior light circuit
Cup holders
965 leather dash
Recaro SPG Pole Position buckets, covered in leather by FVD
Center console with battery and trans temp gauges
Safety Devices full cage
Lindsey Racing 3-outlet 5 lb Halon fire suppression system
37-degree Air Conditioning with Performance Aire underbelly condenser
3.8RS tail with extensions and 50-inch wing
964 retractable tail for street driving
Old 12-17-2002, 05:23 PM
Super Moderator
nostatic's Avatar
no cupholders? Jack...you're slipping...
Old 12-17-2002, 05:26 PM
johncj8989's Avatar
Thats nice and all Jack but what we really want is some detail...
Awesome car......... The force is with you
Chaos, panic and disorder . . . my work here is done
Current Stable
____________
Porsche 911
Mercedes ML430
BMW 328IC
WolksVagon Jetta
Acura TL
Crotchety Old Bastard
RarlyL8's Avatar
Time frame?
Old 12-17-2002, 05:27 PM
Buy them, sell them
Adam's Avatar
I really like the list, Jack... but with fibreglass doors and lexan "lift-up" windows, it'll feel a lot looser than a 911 should. Those doors will slam shut with all the authority of a Dorito!
1968 Ford Mustang Fastback
1985 BMW E28 M535i
1989 911 Carrera 3.2 Cab
2012 Mercedes-Benz C250 AMG
2015 Jeep Grand Cherokee Limited
Old 12-17-2002, 05:28 PM
Senior Member
Superman's Avatar
Speechless.
Old 12-17-2002, 05:29 PM
Never left, but not right
Zeke's Avatar
The gauntlet has been thrown. Who dares to top that? A SoCal hot rod that follows the legacy of the 959.
Old 12-17-2002, 05:41 PM
Hilbilly Deluxe
emcon5's Avatar
No mud flaps?
Tom
82 911SC Coupe
GTI Cup #43
Old 12-17-2002, 05:44 PM
Bill Douglas's Avatar
Nice setup Jack, especially the doors. Adam, the doors weigh a ton Mate, when mine were off the car for repainting I almost put my back out handling them. Noah found much the same with his car.
Old 12-17-2002, 05:58 PM
tight as a bull's ass's Avatar
Jack, you're going to build youself quite a nice race car
gods speed my man
Old 12-17-2002, 06:18 PM
You do not have permissi
john70t's Avatar
Look out world, Jack's back in buisness. http://bekow.free.fr/vroom/index_eng.htm
Old 12-17-2002, 06:40 PM
Brian993's Avatar
Jack leave a little room for the big balls you'll need to run this car out. I know you wont need to look far for them!
http://www.p-caronline.com/directory/brian993
Old 12-17-2002, 06:43 PM
PRO Motorsports
Tyson Schmidt's Avatar
Wow! Check out the V.I.N. number. 777 Very lucky!
R-Gruppe member #382
'69 911E coupe' 2.7E MFI (retired 911-Spec racer)
'72 911T Targa
2004 GT3
Old 12-17-2002, 06:54 PM
wow, that is so hilarious.....LOL
Old 12-17-2002, 07:01 PM
Buy them, sell them
Adam's Avatar
The doors will save a lot of weight, I know.
What's the target weight, Jack?
1985 BMW E28 M535i
Old 12-17-2002, 08:05 PM
Interesting - my '72 was 9112110703!
I feel strong urge to build my own, although I don't have the vast array of experience right here at hand. Or the cash. I've commited to restoring a VW crew cab this winter, so maybe late next year I'll be able to fire a shot across Jack's bow once again...
Old 12-17-2002, 08:35 PM
Administrator
Jack Olsen's Avatar
It will be a pretty awesome car, although that's the really result of the work of people who are a lot more knowledgeable than me. I mostly just write the checks -- the guys at TRE do the heavy lifting.
The cup holder will be carried over, although I'm considering a single-drink model for weight savings. ( )
The target weight is 2200 pounds, which is based on nothing more than hope. We haven't figured out exactly what it ought to weigh. The cage, AC, leather interior panels, the dual oil coolers, tranny cooler, the big brakes -- they all add weight. I'm not even willing to give up the bumper deco trim. (Damned vanity.)
The timeframe is two months, which will test the limits of Kevin's and Dave's shops. But we need to have time to get it sorted out for the OTC if we're going to podium in the new, tougher, class they're putting us in.
Old 12-17-2002, 08:43 PM
she's a craze you'd endorse
she's a powerful force
you're obliged to conform
when there's no other course
She used to look good to me
but now i find her.........
simply irresistible
Then the chorus:
she's so fine
there's no tellin' where the money went
she's all mine
there's no other way to go
Simply Irresistible from Robert Palmer's 1988 album, Heavy Nova
Definitely applies here
Old 12-17-2002, 09:15 PM
Langers's Avatar
No offence intended Jack, but what are you going to do when you crash this one? You did a very good job of handling BB until Laguna, and that was a slower car than this one will be...... Do you *really* think you will be able to handle it?
On another note, this would have to be a very unique car.... who else would have fibreglass doors and leather seats on the same vehicle?
Old 12-18-2002, 12:55 AM
Efrain68912's Avatar
"No offence intended Jack, but what are you going to do when you crash this one? You did a very good job of handling BB until Laguna, and that was a slower car than this one will be...... Do you *really* think you will be able to handle it? "
Its really easy to be an armchair coach.
Sounds like an awesome car, Jack. I look forward to seeing it sometime - hopefully I'll get a look when I go to TRE for the New Years' Day rally.
Efrain
68 912 Coupe
62 A-H Sprite (VARA DP)
97 Van Diemen FC
94 Mazda RX-7
Old 12-18-2002, 01:29 AM
