Too bad you didn't address some of this stuff when you had the engine out to put in the new clutch. If it were me I would look into a decent, documented used 3.0. I think there was one on the parts board here for $4K. You can do an engine swap in a long Saturday with the help of a Pelican with a garage and your core 3.0 is probably worth enough to get the tranny fixed. I would do the motor, put in the Swepco, and make sure your clutch is adjusted right. I bet you can milk that tranny for several more years.
I did not do the clutch myself, a mechanic did it. I asked him about the tranny at the time, and he said it would be $2000 to just open it...the clutch was already $1600, so I said fughedaboudit. At this rate, I `d have spent 10 grant for all the work...
Aurel |
Do the tranny flush, and then switch to Swepco like Superman said. Then check your linkage.
As for the motor, you can rebuild it in your house. RoninLB did, upstairs even:D . I wish I had half the courage he has, to takle the jobs he does. |
The tranny is actually not that bad. Some grinding if I shift too fast, but I agree that Swepco is the way to go. I`d be doing all that if it was not so cold outside ! I have a basement where I could work on the engine, but I would have to drop it outside... I have driven 4000 miles since I discovered the broken headstuds 5 months ago...it may have been even more. Now, I feel it is time to do something.
Aurel |
I had an oil leak too. turned out be be hoses and the oil sender unit and the blowby hose. It looked like a big deal.I paid a guy to drop the engine I didn't have the tools at the time. cost $400 with oil and it was fixed.
| All times are GMT -8. The time now is 03:10 PM. |
