Headlight Washers Not Working
Late '79 with new headlight washers---flush mount type---and neither work. Before installing the nozzles the pump was run and it put out a significant volume of water. Hoses from the T to the washers are new with new clamps---no leaks showing. Water tank was flushed and filled with distilled water. Before installing, I blew into each new nozzle (EDIT: I'll note later in thread that this is an error on my part. I blew into the pressure control valves) and it was very hard but air did pass through. Figured the resistance was to build pressure in the system. I know to turn the headlights on to activate the system. When the washer switch is turned on, pump runs but zip comes out of nozzles. Ideas where to go with this would be appreciated.
Soak nozzles in vinegar overnight, rinse and try again?
Are you sure there is enough water in the tank?
I fought with mine once and was about ready to rip the pump our and replace it. Then I realized the tank was empty. Homer Simpson DOH! |
Following this thread with interest. Neither my headlight washers nor my windshield washers work. They are among the last of the Great List of Nagging Issues to be Resolved(TM).
^^ Check your check valves.
Me three on the check valves.
Look at the two "T's" in the dead center of the yellow.
Those are the 2 check valves. 91462843300 Both mine were clogged shut. On the '86 you need to pull these down from under the cowl area. There is a clip that tucks them away. They are near the nozzles. The exact configuration is preserved in the photo. The "F" connector goes into the bottom of the two "T's" http://i62.tinypic.com/2yoxvzo.jpg |
Pull the hose at the washer pump to eliminate the check valves. If there is no pressure, then jumper the pump with 12v to see if it runs. If it runs but no pressure, then drop the tank and check that the pump inlet screen is not blocked with sludge/ algae.
If your pump passes a lot of water then there could be a couple of things to check. Is the pump still strong enough to work under pressure? Are the valves blocked (# 10 or #16). Are your jets to retrictive?
http://i179.photobucket.com/albums/w...pscavw4xuv.jpg |
Try this, do all the stuff you are supposed to do but drive the car! I could not get mine to work then I went for a ride after everything and they spray like you could not believe while driving. !!! Try it.
Plan is to pull the bumper this weekend and check the valves, nozzles, then the pump for pressure and sludge, maybe get some vinegar into the program. Once this system is sorted, will catch up to Sugarwood. |
Just been advised by security that dismantling my car in my condo's garage can no longer be tolerated... "individuals are opposed to it." Building's association bylaws do say only emergency repairs are allowed in the garage. Having pushed the emergency envelope long enough, there's nothing good to come now from inciting my fellow condo-dwellers to riot. I'll find a space this week where Porsche-works won't offend others. There's much to be said for condo living. There are also sacrifices like this that are a hard pill to swallow. If you're planning to move out of a house and into a condo... prepare yourself for a new world strapped by a multitude of rules & regulations.
When I worked on mine I had to prime them with a 60cc syringe to get all the air out of them and then they worked. Now as preventive maintenance when I know I'm going to wash the car I run mine briefly to keep fresh solvent in the lines. Same with with the window washers
| All times are GMT -8. The time now is 10:54 PM. |
