A brakes question.
On the SC the brakes are wonderful. I could take my hands off the wheel at 60mph and slam on the brakes, and the car would stop in a straight line.
But... I was crawling forward, gearbox in neutral, going slightly down hill and I could hear a brake pad rotor noise. I've put the car up on the hoist and turned the wheels and all of them make a little bit of noise some or most of the way around when the wheel is turn by hand. This suggests the pad is dragging to some extent, but I don't know what is OK and what isn't. I went for a drive without using the brakes then immediately put my finger on the calipers then the rotors, on all four wheels, and they were all cold. So if it is dragging, it isn't by much. What are your thoughts? Is this normal? I was going to remove the calipers from the rotors and decompress the pistons a few times to free things up. But I don't want to if I don't have to. |
Under the radar
Noise? Could be some grit or gravel caught in the calipers.
If you spin the wheel by hand and it continues to spin, I would call that good, considering you say it brakes straight and true and they are not heating up. How long has it been since you changed your brake fluid? Might be a good time to do a complete flush. At when you are bleeding you could push each of the pistons back in the caliper. No need to remove the calipers. How old are your brake hoses?
Thanks Gordon. The brake fluid is about three years old and the hoses are good, umm brake hoses are about ten years old but they get checked every six months. So I can jam a screw driver in there and force the pistons back into the caliper when I do a brake bleed?
the primary means for retracting the pistons is the rotor pushing them. Pad knock back is when they get retraced too far. There is some retraction due to hysteresis in the rubber as well but not much. The result is going to be a slight drag
your fine .
you want the pads as close as possible without putting PRESSURE on the rotors.
Under the radar
Much better to use the proper tool, the pistons aren't all that robust and it's easy to go through the crown.
Under the radar
I've not seen that tool before. Where are those sold?
Thanks guys, a wealth of knowledge between us. Also great to get the Bill V brake guru sign off to the situation
Not quite as fancy as Bill's, but I got one like this off ebay for less than $20. Just search "brake caliper tool".
_______________ John 1988 Carrera Targa 3.2 G50 - Sold. 2017 Chevy Silverado K1500. |
Home of the Whopper
Use a laser thermometer and check rotor and caliper temp after a drive.
If one was dragging, it will have elevated temps. Compare fr with fl; rr with lr. Visually checking your brake hoses won't help with internal swelling. At 10 years old I would personally replace them. But I'm anal like that.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Amazon They were ~$60 when I bought mine they seem to have gone up to ~$100 theses days
the name is 4 in 1 The $20 screw type works as well just not as convenient
Under the radar
Good to know. The only type I have seen looked more like a speculum. Didn't seem too functional.
I bet I could make a screw type.... BTW, I sometimes use a thin but deep C clamp, if the piston is not cooperating.
