-   -   Window motor wiring (http://forums.pelicanparts.com/porsche-911-technical-forum/912799-window-motor-wiring.html)
Wilbo 05-03-2016 08:28 AM
Window motor wiring
Having difficulty finding where the window motor wires connect on the motor. I've got access to the motor and regulator, but I can't see well enough inside the door compartment to see where or how they connect. Any directions or especially pictures would be greatly appreciated. 1986 911 targa. Thanks
Cherry Bomb 05-03-2016 08:35 AM
hoping this helps....
http://forums.pelicanparts.com/uploa...1462293239.jpg
http://forums.pelicanparts.com/uploa...1462293321.jpg
Wilbo 05-03-2016 09:21 AM
So the two yellow connectors are where the two wires connect from the switch to the motor? Sorry I'm new to this procedure. Thanks for the pictures. I'm assuming I remove the two wires at that connection and then I can remove the window motor and regulator??
86 911 Targa 05-03-2016 09:41 AM
Motor.
Are trying to remove the motor?
Or, just the wires?
You can remove the motor without removing the regulator.
pm me as needed.
Gerry
Wilbo 05-03-2016 10:30 AM
I tried to send you a pm. Guess I don't know what I'm doing there also. Haha. Yes I'm just trying to replace my window motor only. I thought the regulator comes out along with the motor?????? Thanks for your replies
sky1jord 05-03-2016 10:32 AM
Gerry
True, but IIRC, you'll still have to detach the regulator from the door to get the motor into a position where it can be unscrewed from the regulator arm.
Also, I was lucky enough to have a switch-to-motor cable that had a 2-terminal connector to mate at the motor end, making it much easier to make a connection than dealing with two independent faston tabs.
Good Luck
sky1jord 05-03-2016 10:36 AM
This should give you further help.
Porsche 911 Window Regulator and Motor Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Wilbo 05-03-2016 05:18 PM
Thanks to Gerry and sky for there advice. I finally got the motor out without removing the regulator. Mine also has a a two cable connector. Can either of you please tell me where I can/should purchase a new motor. Was thinking about a used replacement, but don't want to trust the condition and I'm also not too eager to do this job again anytime soon. Any feedback is always appreciated. Thanks again. Gary
