-   -   3.6 conversion engine support (http://forums.pelicanparts.com/porsche-911-technical-forum/913033-3-6-conversion-engine-support.html)
Duc Hunter 05-05-2016 06:24 AM
Simple question.......which engine support should you run on a 964 motor in a 1975 911? I as because mine has what appears to be a 964 engine support that has (maybe) been bent a little to work with the car's standard engine support mounting points (and mounts).
Is this normal, or do people leverage a Carrera style engine support? If that how so? I am putting new motor and tranny mounts in mine, and want to make sure I have the support proper at the same time.
Just to add my car currently has the 3 row crank pulley on it...so maybe that prevents the use of the Carrera style support?
Thanks!
