Connecting Rod Bolts, recommendation ?
What connecting Rod bolts do you recommend to use in a stock 3.2 engine ?
New Porsche original, ARP or Raceware ? To install them do I need to measure the stretch or just with the torque figure is enough? |
Under the radar
ARP.
IMO torque to the specified # and then measure the stretch. If the stretch is not in spec adjust the torque. If the torque is much outside the specified range, you have a problem.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 05-03-2016 at 11:23 AM.. Reason: tried to get a capital A and R and P ! |
The ARP model number is 204-6005 ?
These are M9 |
Under the radar
Yes. ARP By Patrick Motorsports Porsche & Mid Engine Performance Specialists
Not recommending them as a supplier, but they have the reference to 3,2 on their site. I don't see them on Pelican.
Trackrash,
Thanks. It is not clear if that part number will fit the 3.2 engine. I checked different sites and I am getting confused. The ARP catalog mentions 3.0 and 3.3 but no 3.2. In other sites they say the con rod bolts are the same for most all Porsche engines ?????? I did not find these at the Pelican parts catalog. |
Under the radar
More confirmation. Help: Rod bolt identification see post #5
Do a search in the Engine rebuild forum. Lots of info.
+1 for ARP. I got them from EBS but I just checked their site and don't see them anymore.
Mat P 1988 911 Carrera |
Diss Member
You can't go wrong with either ARP or Raceware. ARP is more popular and available. I would go with the best price.
The stock 3.2 bolts are the weak point in the 3.2's bottom end. (I like to call them rev limiters.) No reason to consider them for a rebuild.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
abides.
3.2s and 3.3s used the same rods. The bolts are the M9 size. 204-6005 is correct.
Graham 1984 Carrera Targa |
Thanks for all the answers.
Ordered ARP 204-6005 |
abides.
I would suggest using a good stretch gauge for installation.
This has been discussed in other ARP rod bolt threads, but mine needed a few extra ft-lbs of torque to reach the specified stretch.
ARP is what we use.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
