-   -   How do i fined the Engine number (http://forums.pelicanparts.com/porsche-911-technical-forum/913495-how-do-i-fined-engine-number.html)
slow car 05-08-2016 06:24 PM
Hi I have a 69 T that has had a rear end collision and the place where the engine number should be is missing ?
Where can i fine the original engine number?
I have the chassis number
John
pors1968 05-08-2016 06:39 PM
Do you have pict right side engine near alternator.
HarryD 05-08-2016 08:39 PM
To find the engine serial number look where the arrow is pointing in the picture below:
http://forums.pelicanparts.com/uploa...1206862764.jpg
This picture shows you what the serial number stamp looks like:
http://forums.pelicanparts.com/uploa...1147898340.jpg
Here's a picture showing where both the serial and engine numbers are:
http://forums.pelicanparts.com/uploa...1093184101.jpg
slow car 05-09-2016 03:36 PM
Thanks for the reply , The lug where the engine number should be was smashed off in the rear end collision, is there any other place on the car i would find the correct number ?
john
HarryD 05-09-2016 04:20 PM
john
If that was broken off, you do not have a motor left.
How about a picture?
pors1968 05-09-2016 05:07 PM
You can have your engine number if you get COA .Your engine must be in pretty bad shape and useless.
RichardNew 05-10-2016 03:22 AM
Wow I need to see pictures. That had to be a really heavy hit.
Richard Newton
The Future of Car Shows
