wide body gravel guard
Does anyone have tips on installing the black adhesive gravel guards on a widebody?
A friend suggested a soapy mixture applied to the sticky side gives some play?
Hope someone has done these and knows the tricks.
Old 05-10-2016, 07:11 PM
billydeakins's Avatar
I think Rennline makes some magnetic ones as well....may be another option for you.
1989 911 Carrera 3.2, Guards Red
Old 05-10-2016, 07:19 PM
Just like any other body decal, clean clean clean surface. Then mix water and a few drops of dish soap. Apply to the surface and vinyl (a hand sprayer works best). Play around with it until you find the perfect location, then squeeze out the excess water with a credit card or similar starting slowly from the center out taking out all the bubbles. Finish with more pressure and let the adhesive dry for at least 2 hours. Rinse area.
MD
"With an stock-original car, you serve the car. With a hot-rodded car, the car serves you."
Old 05-10-2016, 07:30 PM
