quick questions
What is the compression ratio for a 2.4T and can mid grade gas be used, 89 octane.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 05-12-2016, 03:01 AM
As I recall, 2.4 S is 8.5 CR, E is 8.0, T is 7.5 CR.
Anything will run in any of the CRs
Old 05-12-2016, 03:16 AM
tobluforu's Avatar
If its a stock mfi car and you don't run a lot of advance, then 87 works just fine.
Old 05-12-2016, 03:35 AM
Now that was quick. Thanks.
gary
Old 05-12-2016, 04:45 AM
Interesting, but here in Montana (and elsewhere too) I can find alcohol free gasoline but it's 91 octane. Am I wasting my money? By avoiding the water-gathering nature of ethanol, I don't think so. Should I adjust my mixture to compensate? (I have a '75 911 Carrera engine.)
Questions beget more questions!!!
Thanks,
Tom
Old 05-12-2016, 09:23 AM
HarryD's Avatar
Tom:
The risk of ethanol to our cars is from corrosion of the steel and rubber parts wetted by the fuel. The metal corrodes and the original rubber gaskets are not compatible with ethanol. The octane is a secondary concern. It does not hurt to have too much octane.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-12-2016, 09:53 AM
